C52 and C56 - Toyota Nation Forum : Toyota Car and Truck Forums
Old 02-12-2007, 07:17 AM   #1 (permalink)
View igorien2k's Photo Gallery
C52 and C56
*EDIT* i meant to say C160
are they pretty much interchangeable? meaning that any engine that came attached to a C52 will attach to a C160? what about axle lengths? will they have to be modified for most models?
igorien2k is offline   Reply With Quote
Old 02-12-2007, 10:40 AM   #2 (permalink)
KDM is in
REN69's Avatar
Gameroom cash: $273221
View REN69's Photo Gallery
They are interchangeable to a point, I believe the axles will also work. The only problem I believe is the fact that the C160 is longer (extra gear) therefore you need to move one of the mounts on most cars (AE92/101, etc).
Check the Master Corolla Sticky on the top of the Corolla forum, there's a sticky related to C160 transmissions into AE92s.
Old 02-12-2007, 03:08 PM   #3 (permalink)
well i can pick up a tercel body for cheap and get a 4efte motor for about $800 shipped to my door so I was hoping to fit this tranny in a tercel with a 4efte swap
Old 02-12-2007, 08:45 PM   #4 (permalink)
The TN Member
View punter's Photo Gallery
A c160 will bolt to an A series engine, It won't bolt to an E series engine, as in the 4Efte.
If you want to run a c52 and 4efte combination you'll need to source a c52 from a GT starlet.
(It is apparently possible to put a corolla box onto a E engine, but it requires alot of work and custom fabrication, ie not worth it)
Say no to huge pics as signatures.
punter is offline   Reply With Quote
C56 final drive 94_Rolla_Guy Archived Corolla threads 6 11-16-2005 01:46 PM
C56 Trans vs C52 EProd23 Archived Corolla threads 6 01-25-2005 03:41 PM
