92 rear brakes prob - Toyota Nation Forum : Toyota Car and Truck Forums
Old 02-12-2007, 12:38 PM   #1 (permalink)
View dfroirvde's Photo Gallery
92 rear brakes prob
so i just put new brakes on my friends 92 corolla (front and rear). and when i went to bleed them, the pass rear drum was dumping fluid. so i took it apart again and the piston was leaking from the seals (small mystery hole). i picked up a new piston (or wheel cyclinder, whatever you wanna call it) and i tossed it in. i pumped up the brakes again and kablam! fluid everywhere. pulled the drum off and the rubber seal boot thing popped of the piston. so i put it back on and the same problem happened. i am going to pick up another cylinder today and hope that it was just a defective replacement part. but my question is...does anyone have any ideas as to what would cause this???? i dont want it to pop off while she is driving and then have the brakes not work.
dfroirvde is offline   Reply With Quote
Old 02-13-2007, 08:54 AM   #2 (permalink)
All-Trac Guru
ghost_ryder35's Avatar
View ghost_ryder35's Photo Gallery
more then likley a bad part. just make sure the e-brake works and she knows where the e-brake is and everything will be fine
89 Corolla All-Trac Sedan White 188,xxx (Sold)
89 Corolla All-Trac Wagon Blue 172,xxx (Current)
ghost_ryder35 is offline   Reply With Quote
Old 02-13-2007, 12:05 PM   #3 (permalink)
retiredat44's Avatar
View retiredat44's Photo Gallery
Cool
that's very odd....
I've done more than my share,,, and never had a new one leak, in fact enver had any real bad leaks with holes, just corossion,, in fact we used to use emery cloth on the old cast iron ones and that would clean and fix them, put them back together, an all new..
retiredat44 is offline   Reply With Quote
Old 02-13-2007, 01:34 PM   #4 (permalink)
Resident asshole
Flashmn's Avatar
Gameroom cash: $352045
View Flashmn's Photo Gallery
Obviously you did something wrong... now did you bleed the brakes with the drum on and the shoes on it? Because the pistons wouldnt pop out if everything was together.
Whiteline; Superpro and Dobinson Group Sale ...PART II raptorracing Supporting Vendor Sales 93 05-02-2007 05:02 AM
92 Tercel rear and brake lights NickR Tercel, Paseo, Starlet, and Sera Forum 3 08-01-2005 06:12 PM
Need urgent help with Brakes on my 92 V6 92V6xle 3rd & 4th Generation (1992–1996 & 1997–2001) 5 04-13-2005 02:53 PM
Buddy's Camry '92 rear light issue Loka_K 3rd & 4th Generation (1992–1996 & 1997–2001) 2 03-15-2005 12:26 PM
Conversion Kit - Rear Drum Brakes To Disc Brakes Nikolas Archived Corolla threads 5 08-20-2004 10:38 PM
