headlamp replace( the whole thing) - Toyota Nation Forum : Toyota Car and Truck Forums
Old 02-14-2007, 04:17 PM   #1 (permalink)
View sdbct1's Photo Gallery
OK,
I was looking on ebay and thougth After all the great info on the bulbs, it would be stupid of me to relace them without replacing the whole cover. Lens etc. Now any clue as to are these things just bolt into the origional spot? Or do they need mods? I need to get new ones. One of mine had to be replaced after a cop blew a stop sign and hit me. It's all cloudy. Thanks gang.
sdbct1 is offline   Reply With Quote
Old 02-14-2007, 08:44 PM   #2 (permalink)
TIEyota fighter ace
Piloter's Avatar
Gameroom cash: $143400
View Piloter's Photo Gallery
They bolt in, although they may or may not fit perfectly. Getting the headlights in and out is a surprisingly annoying process because the side markers and main enclosures are linked together. You'll probably wind up snapping something in the process of removal...but it shouldn't impact your ability to get the new ones in and solid. (I didn't bother reconnecting my side markers with the main enclosures, and as such both of them are easier to get at for adjustment or bulb replacement. Set aside a good couple hours worth of light to do this...it may also help if you remove the battery to give yourself a little more room to work in.
I would also recommend taking it to a shop when you're done and getting them to properly aim-adjust the headlights for you.
WIP AE102.
Piloter is offline   Reply With Quote
Old 02-14-2007, 08:47 PM   #3 (permalink)
Thanks dude,
Now this is gona sound like a dumb question, But do the headlights have 2 bulbs hi/low beam? or just one?
Old 02-14-2007, 08:51 PM   #4 (permalink)
TIEyota fighter ace
Piloter's Avatar
Two bulbs per headlight, yes. 9005 high-beam and 9006 low-beam.
WIP AE102.
Old 02-15-2007, 12:04 PM   #5 (permalink)
Thanks dude
ignition leads replace one or the lot???? 94_v6_camry 3rd & 4th Generation (1992–1996 & 1997–2001) 2 07-29-2006 01:07 PM
Replace Bearing and Camper costs $492 kdyj 3rd & 4th Generation (1992–1996 & 1997–2001) 3 06-01-2006 03:27 PM
What the hell is this thing!?! Grayguy Off Topic 9 01-30-2006 05:52 PM
Valve Stem seal replace HELP !!! KevinLi Camry & Solara Lounge 3 04-11-2005 04:32 AM
The bulb for my transmission stick went out, how to replace? takkie Archived Corolla threads 11 12-27-2003 02:45 PM
