ae86 crank pully/keyway - Toyota Nation Forum : Toyota Car and Truck Forums
Old 02-17-2007, 05:05 AM   #1 (permalink)
kouki ae86
stealthtrueno's Avatar
View stealthtrueno's Photo Gallery
whats the easyest way to remove the crank pully and is it reverse thread? also can i use the 20v crank pulley on my 16v? and where can i buy a new keyway?
AE86 FTW!
stealthtrueno is offline   Reply With Quote
Old 02-17-2007, 05:12 AM   #2 (permalink)
kouki ae86
ttt
AE86 FTW!
Old 02-17-2007, 01:38 PM   #3 (permalink)
kouki ae86
nvm figured it out
AE86 FTW!
Old 02-17-2007, 08:37 PM   #4 (permalink)
Gameroom cash: $134355
EASIEST way isn't the safest way (but don't at shops.... even by toyota mechanics)
what you do is get a 1/2" breaker bar with a cheater bar to lengthen it.... with those attached to the crank pulley, jam the breaker bar against the frame (or anything VERY sturdy.... i've even done it by holding the cheater bar myself)
then have someone click the starter over.... the car does all the work for you....
if you're lucky, then the pulley won't be welded to the crank via rust (which happens sometimes) and you can just wiggle the pulley off..... the woodruff key will come off when you pull the lower timing gear off
Old 02-18-2007, 01:16 PM   #5 (permalink)
kouki ae86
thanks man. do i need a crank puller?
AE86 FTW!
who has lightened crank pulley's done? boroEF Hardcore Tech and Competition 33 07-14-2004 11:03 AM
very very long arguement bout ae86 martiniracing Feedback: Buyers, Sellers, and Vendors 9 10-31-2002 08:41 PM
