redid head gasket - Toyota Nation Forum : Toyota Car and Truck Forums
Old 02-17-2007, 10:29 AM   #1 (permalink)
View hypermaxed's Photo Gallery
redid head gasket
i just redid the head gasket on a 1992 toyota corolla with the 1.6 dohc engine. i was wondering if anyone knew the timing on the engine and also if anyone knows the torque settings for the head bolts
thanks for any help
Corey Davis
hypermaxed is offline   Reply With Quote
Old 02-17-2007, 05:29 PM   #2 (permalink)
View tnmk's Photo Gallery
Timing is 10 btdc. and the torque is weird. I'll check my manual and get back to you tomorrow. But I think it's 22 ft lbs. then (going in the right order) turn 90 and one more time around for anothe 90 for a total of 180.
Why they don't just give a torque setting I don't know?
tnmk is offline   Reply With Quote
Old 02-17-2007, 05:43 PM   #3 (permalink)
Resident asshole
Flashmn's Avatar
Gameroom cash: $352045
View Flashmn's Photo Gallery
IIRC Your torque specs are wrong.
The bolts arent stretch bolts. On the older head it was something along the lines of 20-40-60NM. I'll double check from autodata on monday when I hit the garage.
Old 02-18-2007, 08:18 AM   #4 (permalink)
Mine is a 93. was there a change from 92-93?
My factory service manual for my 93 Geo Prizm with the 1.6 Toyota DOHC says 22 ft lbs or 29 Nm and then re-tighten 90 degrees and then another pass at 90 degrees.
Proper torque pattern is as follows
8 6 1 3 9
10 4 2 5 7
My Haynes manual says the same thing. It's range is year 1993-2000 So there may be a difference.
Hope this helps
Old 02-18-2007, 11:59 AM   #5 (permalink)
Resident asshole
Flashmn's Avatar
92-97 would be the same. Like I said, I'll check it tomorrow.
Do remember that the 4A-FE has a different torque setting than the 4A-GE. 4A-GE uses stretching bolts, 4A-FE doesnt.
Old 02-18-2007, 03:38 PM   #6 (permalink)
i need the cam timing not the engine timing
Old 02-18-2007, 03:43 PM   #7 (permalink)
Resident asshole
Flashmn's Avatar
If its a 4A-FE theres installation marks on the inner side of the camgears.
Then you just rotate it so that the camgear hole points to the marking point.
Old 02-18-2007, 04:32 PM   #8 (permalink)
You really should have a manual for this job. When you removed the intake cam did you secure the 2 gears together with a 6mm bolt?
And then for instalation there are a few different marks and I'm not sure how to explain it without the diagram Or typing a long explanation which at the moment I don't have time for. There are both installation marks as well as timing marks. Torque for the cams are 115 in lbs(that's inch not foot) or 13 Nm
I think if you do a search on the forum here there are some manuals within the site that will tell you a lot of info.
If I had more time I would type more. Sorry,
Good luck
Old 02-18-2007, 05:09 PM   #9 (permalink)
Resident asshole
Flashmn's Avatar
Doing this without a manual is kinda like wiping your ass with sand paper. You can do it, but theres lot of things that can go wrong.
That can be done with the cams out, if he didnt do it. So its not going to be the end of the world.
Old 02-18-2007, 05:44 PM   #10 (permalink)
View cheesep's Photo Gallery
The vehicle repair guides at www.autozone.com may help. . .
cheesep is offline   Reply With Quote
Old 02-19-2007, 01:57 AM   #11 (permalink)
ok we got the cams on right we remembered how they were when we took them off ... got a late start today ... hopefully tomorrow i can report i have it running
Old 02-19-2007, 08:31 AM   #12 (permalink)
Resident asshole
Flashmn's Avatar
Shit I forgot to look it up... Heh worked on a race car mitsubishi lancer the whole day, so it slipped my mind.
Old 02-19-2007, 04:52 PM   #13 (permalink)
yay!!
well we got her back together ... timing was right on the money no blow out of the overflow bottle looks like the new gasket is working was gonna test drive but forgot i needed gas in it lol so will report back later....
Old 02-19-2007, 08:29 PM   #14 (permalink)
sweet, everything works had a lil scare, it was sucking up the water in the overflow bottle but turned out just to be an air bubble trapped, took of the rad cap and it burped, put it back on took it around the block and it works fine
Blown Head Gasket? Block Seal? 89_3SFE Camry & Solara Lounge 11 07-20-2006 12:09 PM
metal head gasket for a 4afe woodenhead72 Archived Corolla threads 9 07-12-2006 11:22 AM
1993 4 runner head gasket blown! peanutzz 4Runner Lounge 4 02-15-2006 10:45 AM
Head gasket theory needed peterng 89-95 Toyota Pickup/Hilux 4 01-15-2006 09:51 PM
