Jumpy idle need diagnosis - Toyota Nation Forum : Toyota Car and Truck Forums
Old 02-19-2007, 06:01 PM   #1 (permalink)
ae92redtop's Avatar
View ae92redtop's Photo Gallery
AE92 Jumpy idle need diagnosis
Hey toyota nation.... Im having a realy jumpy idle, and never had this problem before. A few weeks back i noticed it was overheating and leaking antifreeze. I tested the radiator and found the leak. Due to the weather; my new radiator finally arrived. I installed it, and filled up the radiator with 50/50 blend (coolant /distilled water). Now time for me to start her up; so that the thermostat will open up, and i could finish filling the radiator. Only now the idle seems realy rough, and jumpy. The coolant dosnt seem to be going into the engine at all. My geuss is that the thermostat is stuck closed. Im not exactly sure where the thermostat is located though.. 4AGE
Is it possible that my water pump is busted?
ae92redtop is offline   Reply With Quote
Old 02-19-2007, 06:08 PM   #2 (permalink)
Donald's Avatar
Gameroom cash: $201420
View Donald's Photo Gallery
Do a compression check. Overheating can cause piston rings to break, and you don't want to keep running an engine with broken rings, they can score the cylinder walls.
'88 Corolla, AE92 SR-5, 7A-FE swap/GT-S suspension
'87 Corolla, AE82 FX-16, 4A-GZE swap (autocrosser)
'03 Tundra 4X4 Access Cab, (FX tow vehicle/Home Depot runner)
Modification: Changing something to what you thought it should have been from the start!
Donald is offline   Reply With Quote
Fluctuating idle with AC on and brake pressed - DEFINITIVE FIX!!!! ovrrdrive 89-95 Toyota Pickup/Hilux 12 03-24-2007 04:24 PM
Proper Idle speed for 22re capinoy 89-95 Toyota Pickup/Hilux 2 01-29-2007 07:16 AM
99 4-cyl idle air valve removal sixto Camry & Solara Lounge 3 02-18-2006 01:16 PM
Low Idle when cold and when AC is on Tom Simon Hardcore Tech and Competition 3 04-02-2005 03:04 AM
No Idle after motor rebuild wrenchdad MR2 Forum 0 01-09-2005 08:19 AM
