Have you CV joint removal tips? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 02-20-2007, 01:11 AM   #1 (permalink)
TN TE/AE/SW Afficionado
View Chucez's Photo Gallery
AE92 Have you CV joint removal tips?
So I've been hammering away at my CV joint for the past two days and I can't seem to get the darn thing off.
I'm hoping that someone can give me a tip as to where the best place is, to hit the joint, in order to get the joint off.
Does force, that hits the joint, have to be parallel to the axis of the axle?
I really appreciate any tips or input, thanks in advance!
'86 4-Runner Turbo
^^^^ The fantasies of a horny manatee.
Chucez is offline   Reply With Quote
Old 02-20-2007, 10:29 AM   #2 (permalink)
View tashirosgt's Photo Gallery
Driver's side axle or passenger's side?
http://www.corolland.com/forums/inde...128&hl=Stanley
tashirosgt is offline   Reply With Quote
Old 02-20-2007, 12:19 PM   #3 (permalink)
I'm trying to pull off the wheel-side joint on the driver's side of my Ae92. From my experience, it's supposed to come off easily, but it's not doing that. I guess I just have to force it off. but yeah, lemme know what you think.
'86 4-Runner Turbo
Old 02-20-2007, 03:41 PM   #4 (permalink)
is it even possible to remove the outboard joint?
That's where i've been hitting it to get it off of the spline.
'86 4-Runner Turbo
Old 02-20-2007, 03:45 PM   #5 (permalink)
The TN Member
View punter's Photo Gallery
Yes they do come off, you really need a press to do it. It took almost 6 tonns of force to pop mine out (on my brothers press).
If you can't use a press, then heating it with a gass torch and smashing it with a hammer is your next best bet.
Note: both of these methods will probably destory the joint, but thats fine cos it's probably wrecked anyway.
Say no to huge pics as signatures.
punter is offline   Reply With Quote
Old 02-20-2007, 03:56 PM   #6 (permalink)
JUST RE ENGINEER IT
fredk's Avatar
View fredk's Photo Gallery
good luck getting it off, its lots easier slipping the inner yolk off
Old 02-20-2007, 04:41 PM   #7 (permalink)
Resident asshole
Flashmn's Avatar
Gameroom cash: $352045
View Flashmn's Photo Gallery
Punter, the way AE92 CV joints are made, they're practically impossible to take off without destroying the joint.
Old 02-20-2007, 05:35 PM   #8 (permalink)
lol... yeah, I actually made that decision as soon as punter put that up. so much for the might of the brass bar.
'86 4-Runner Turbo
Old 02-20-2007, 05:43 PM   #9 (permalink)
The TN Member
Yea I know been there done that. Though I did manage to get 1 of my ae101 joins off with only a little damage.
Old 02-26-2007, 10:52 PM   #10 (permalink)
schn0354's Avatar
View schn0354's Photo Gallery
Usually the entire CV half shaft is replaced with a new ($110) or remanufactured one ($70). If you do not use a press for removal, the CV joint will be damaged.
schn0354 is offline   Reply With Quote
91 Camry: Should I try to change cv joint boot? alkon 1st & 2nd Generation (1983–1986 & 1987-1991) 0 08-09-2005 08:19 AM
cv joint stuck kaosz Archived Corolla threads 1 08-23-2004 10:36 AM
drive shaft - cv joint wbs3375 Archived Corolla threads 1 08-04-2004 08:48 AM
driver side CV joint removal profuse007 Camry & Solara Lounge 7 07-29-2004 09:45 AM
broken CV joint and wheel hop wontonjohnny Camry & Solara Lounge 9 12-09-2002 10:46 PM
