How do I mark timing??? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 02-22-2007, 07:52 PM   #1 (permalink)
View stubborn1's Photo Gallery
I'm in the process of pulling the head on my 98 Prizm and have never pulled the head on a DOHC motor before or anything OHC for that matter - only old school pushrod engines.
I'm at TDC on cylinder #1 (yes, that is my high precision screwdriver used for measuring TDC ). The picture below shows the cam sprokets. Where is the best place to make my marks
stubborn1 is offline   Reply With Quote
Old 02-22-2007, 07:56 PM   #2 (permalink)
View deekay140's Photo Gallery
looks to me like you're 180 out.. set the the crank to 0. cam gears dots pointed up.
mark the chain link at the gear mark.
Are u pulling the timing cover?
also, its an interference motor, so dont have it at tdc when u tighten down cams
deekay140 is offline   Reply With Quote
Old 02-22-2007, 08:49 PM   #3 (permalink)
Yep - I was off 180. I didn't zero the mark on the crank. The timing cover will be coming off, but my factory manual said to set TDC on cylinder 1 before pulling off the crank pulley and other acc in the way of the timing cover.
Old 02-22-2007, 09:06 PM   #4 (permalink)
Nad1370's Avatar
View Nad1370's Photo Gallery
Actually, the chain links have 3 marks on them (diff colored links). 1 for the exhaust cam gear. 1 for the intake cam gear. and one on the crank gear.
You can also use this to line up your timing if you some how forgot.
Nad1370 is offline   Reply With Quote
My Timing belt change (very detailed, pics) Gen 4 JerryGiese 3rd & 4th Generation (1992–1996 & 1997–2001) 166 04-09-2012 10:44 PM
Changing V6 Timing Belt Pics and the $270 Coil Connector marc780 5th & 6th Generation (2002-2006 & 2007-2011) 81 04-09-2012 07:26 AM
Anyone know the correct timing mark? qeg84dox Camry & Solara Lounge 6 11-09-2005 12:55 AM
Timing mark for 45 degrees BTDC cwhutchings Camry & Solara Lounge 4 05-18-2005 12:12 PM
4afe timing mark Santiagojimbee Camry & Solara Lounge 2 12-03-2004 07:11 PM
