engine stall problem - Toyota Nation Forum : Toyota Car and Truck Forums
Old 02-22-2007, 10:03 PM   #1 (permalink)
View yeding's Photo Gallery
I recently bought a 2000 prism with 114,000 miles on it. the car works fine. but this morning, after I started the car and drove 30 yards to a stop sign (without warm up the eigen), the egine cut off by itself and I had to start again. this also happened weeks ago. is there something wrong with my engine or I just need a tune up? can anyone please give me some clues. BTW, my car is a little bit shaking in ilde. and there's a lot of black powder in the tail of the exhaust tube.
any advices will be appreciated, thx
yeding is offline   Reply With Quote
Old 02-23-2007, 01:59 AM   #2 (permalink)
View toyomoho's Photo Gallery
Do you mean soot in the tailpipe? Might be the MAF sensor or IAC valve needs cleaning.
Old 02-23-2007, 09:39 AM   #3 (permalink)
ye. so that may cause the engine to be stalled? thx
how much does it cost to chage the MAF sensor and clean the IAC?
Old 03-23-2007, 11:25 AM   #4 (permalink)
View crypticlineage's Photo Gallery
MAF sensors are a bit expensive but you should be able to get an aftermarket one for under $100. You could try cleaning it first.
MAF sensor sits on the pipe that connects air filter assembly to throttle body/intake manifold on the engine. It should have a label that would read MAP or MAF. You can disconnect it and spray the wire inside it with some cleaner (google), the wire is the sensor. Definitely google "MAF Cleaning" to get a tutorial, there should be many floating around on the web. I am going to need to do this exercise myself.
While you're at this, you may also want to check on throttle body (aluminum small pipe sitting between intake manifold and air filter assembly under the hood). Its a annual maintennance item. Again, google is your friend.
I dont know much about IAC valve cleaning (guys, is it also called PCV?). If it is another name for PCV, just change it (only $5 at dealer), dont bother cleaning.
Let us know how it all went.
crypticlineage is offline   Reply With Quote
4AGE swap 1992corolla 6th Generation (1988-1992) 26 09-11-2010 11:48 AM
20r Rebuild From Hell! nwdetectorist Pre-88 Toyota Pickup/Hilux 19 09-06-2007 09:38 AM
2jz-gtte Jmac279 Supra Forum 30 02-02-2007 12:54 AM
battery leak eating engine bay... (and weird CD player problem) brownyy Camry & Solara Lounge 17 04-17-2006 11:28 PM
List of Toyota CEL Codes Marc M 2nd Generation (2005+) 2 03-30-2006 12:49 PM
