Torn Driveaxle boots.... - Toyota Nation Forum : Toyota Car and Truck Forums
Old 02-23-2007, 08:05 AM   #1 (permalink)
View Valkyrie90AE92's Photo Gallery
AE92 Torn Driveaxle boots....
My car has her front lifted up since I am doing a brake job. I checked the driveaxle boots since I was there, and BOTH are torn up. Not just a little rip, but plain torn. They are a 2 or 3 piece unit now Now, I know that it isnt good when they are torn. Problem is I dont know how long they have been that way. While driving at highway speeds, I notice the car tends to feel like it is being pushed to the sides as if by a strong wind. You can feel it at slower speeds, but above 55 or so you really feel it. You will be going straight one moment, and the next the car jumps a bit to the left or sometimes the right (usually left). Obviously, I am keeping the car to local runs only--45MPH and less. It used to be really slight, but it is really more pronounced as of late. Is it possible to just replace the boots and look for my problem elsewhere (like tie rods, that kind of thing), or can damaged driveaxles be the culprit?
Car is a 1990 Corolla sedan 5 speed with 202K.
Thanks !
Valkyrie90AE92 is offline   Reply With Quote
Old 02-23-2007, 09:13 AM   #2 (permalink)
Resident asshole
Flashmn's Avatar
Gameroom cash: $352045
View Flashmn's Photo Gallery
Heres my advice, if they're the inner joints, take the shafts out, thoroughly clean them and inspect for dirt damage. IF they're the outer joints, well you cant take them apart without breaking them, so in that way you're screwed.
Old 02-23-2007, 10:37 AM   #3 (permalink)
If by outer joints you mean the ones next to the rotors, then yes, those are the ones that are torn to shreds. As far as I can tell, the ones towards the engine seem to be good.
I'm screwed, aren't I?
Old 02-23-2007, 01:49 PM   #4 (permalink)
View tashirosgt's Photo Gallery
There are boot kits with a boot that can be put around the joint without removing the end of the axle from the hub. (I've never been tempted to use one myself.) If you have some time to work on your car now, you should consider replacing the CV joints.
tashirosgt is offline   Reply With Quote
Old 02-23-2007, 02:41 PM   #5 (permalink)
Resident asshole
Flashmn's Avatar
Yeah, but new boots arent gonna help if theres stones and rocks and dirt in the CV joints, they will wear out ultra fast with broken boots. So if you're lucky they're fine, if you're not, then well yeah you're F'd. :\
Old 02-24-2007, 09:40 AM   #6 (permalink)
View VBAE92GTZ's Photo Gallery
With 202k have the CV's ever been replaced? If not it would be a good investment. Its a pretty simple to do and shouldnt take much more the a couple of hours to do.
VBAE92GTZ is offline   Reply With Quote
Old 02-24-2007, 09:42 PM   #7 (permalink)
View toyomoho's Photo Gallery
You can do the split boot thing but people seem to have poor results. As Flashmn states sand and everything else may have gotten in and the grease excaped. Odds are good you will be looking at worn out joints sooner then later even if you replace the boots.
Old 02-25-2007, 09:02 AM   #8 (permalink)
Gameroom cash: $201310
View ganda1f's Photo Gallery
Had to change the boot on my joint a couple months ago on a AE101. I was tempted to use the split boot but decided not to. In my opinion, it should only be considered a (very) emergency solution if at all. The one I got (Optifit from Toyota by the way) had to be glued together, I don't know of any other kind. Keep in mind, that you have to do it under the car, after filling the boot with grease. Maybe, you could pump the grease in somehow, using some sort of thin tube, but I doubt it. Anyway, I wouldn't count on having any clean surface to put the glue on, after all that.
ganda1f is offline   Reply With Quote
Old 02-25-2007, 02:47 PM   #9 (permalink)
As far as I can tell, from the records, the boots were changed around 100K or so by the previous owner. I dont see any mention of driveaxle replacement in any of the receipts I have, so I am assuming they are the originals. I guess I better start shopping for some Should I stick with Toyota parts, or will anything out of a parts store be alright?
Old 02-25-2007, 11:47 PM   #10 (permalink)
Toyota parts are very high quality but much more expensive. There are on-line vendors that sell Toyota parts at a discount over the dealer. Most but not all axles available from after market vendors are “rebuilt.” Try shopping around on-line and calling stores. Rockauto sells axles on the web, be sure to get the right one for your car. I would get a new axle over a rebuilt one even if this meant a little extra cost.
I have not had good luck with NAPA axles; two defective ones before getting one that fit and did not start clicking within a few miles (not installed on a Toyota car). Just because an axle is guarantied does not make it any easier to take the front end apart due to a bad part.
Old 02-26-2007, 09:12 AM   #11 (permalink)
I guess Ill avoid NAPA then. Besides Rockauto, what are some other good Toyota part vendors? Kinda new to Toyota, so I dont know exactly where to go for parts other than the dealer.
Thanks
Old 02-27-2007, 05:55 PM   #12 (permalink)
diver9000's Avatar
View diver9000's Photo Gallery
Call the toyota dealership in houston and ask for Jeff. Thats probably going to be your best dealer price around. You can try O'reillys or cyberauto.com
diver9000 is offline   Reply With Quote
Stuck - removing RH driveaxle from bearing mount awmccready Camry & Solara Lounge 12 04-16-2011 06:53 PM
Camry V6 LHS Driveaxle Removal davidf Camry & Solara Lounge 1 02-19-2006 04:14 PM
Steering rack boots torn into two pieces after a firestone alignment, need input ruoknow Camry & Solara Lounge 10 11-17-2005 03:39 PM
Strut boots! Fix or Forget? eyeball96 Camry & Solara Lounge 7 03-27-2005 01:53 PM
CV Boots - How to? Floyd Archived Corolla threads 1 01-16-2004 12:48 PM
