Rear wheel noise but no play - Toyota Nation Forum : Toyota Car and Truck Forums
Old 02-24-2007, 09:20 AM   #1 (permalink)
View mchongct's Photo Gallery
Canada Rear wheel noise but no play
Hi,
My right rear wheel makes some humming noise. There isn't any play when I jacked it up and moved the wheel up/down/left/right.
However, when it's jacked up, i tried turning the wheel, it sounds louder than the other rear wheel. hummm..hummm....
Is it the bearing that is causing the noise?
If yes, should I change it?
If I need to change it, is OEM better or non OEM is the same?
Thanks for your help.
Mike
mchongct is offline   Reply With Quote
Old 02-24-2007, 09:33 AM   #2 (permalink)
View VBAE92GTZ's Photo Gallery
More than likely it is the bearing. I had a front bearing go bad in mine. It was loud as hell when driving but had no play. It wasnt till I actually pulled it off when you could feel the bearings catching. I replaced both sides and it was a world of difference. You really need to replace it if not both sides. And as far as OEM its all preference. If you want to spend an arm and a leg at a dealer than go ahead. I got mine from a Advanced.
VBAE92GTZ is offline   Reply With Quote
Old 03-07-2007, 10:11 PM   #3 (permalink)
Canada Fixed
Thank you, it was true, the wheel bearing was causing the noise.
I tried looking for the parts from after market and dealer. Toyota only design the whole hub and not just the bearing.
I sent it back to Toyota to get it fixed. It cost me $450 for the part! the total bill came to $620 ! That's too expensive!
Anyway, I had bad experience with after market stuff that's why I went for OEM this time. But the OEM might not be worth it, as the warranty is the same as after market.
Anyway, thanks for the help, at least it's fixed.
cheers.
Old 03-08-2007, 01:34 PM   #4 (permalink)
View banting's Photo Gallery
Originally Posted by mchongct
Hi,
If my wheel (left rear) does move a little bit when i jack up and move, then mostly what's wrong with it?
banting is offline   Reply With Quote
Old 03-08-2007, 02:26 PM   #5 (permalink)
Vroom?
freakinbox's Avatar
View freakinbox's Photo Gallery
you check a bearing two ways, jack it up and see if there is some play in the wheel, there should be none. And the other thing you do is spin the tire to see if it spins freely
1989 Corolla sr5, 4af, 1990 gts seats, TRD short shifter.
http://www.cardomain.com/ride/2061750
freakinbox is offline   Reply With Quote
Should I Skip The Camry Alltogether?!?! hikix 5th & 6th Generation (2002-2006 & 2007-2011) 104 05-29-2008 11:33 PM
Rear wheel alignment problem on 2004 corolla S Fv53 Archived Corolla threads 1 02-19-2006 07:50 PM
Help with screeching noise when turning the steering wheel Ghetto2315 Archived Corolla threads 3 01-12-2006 06:11 PM
Need diagnosis help 90 Gen2 Camry & Solara Lounge 4 06-19-2005 11:20 PM
