Rough idle; stalling at speed - Toyota Nation Forum : Toyota Car and Truck Forums
Old 03-02-2007, 12:42 AM   #1 (permalink)
View Ranger X's Photo Gallery
My friend has an '00 corolla and he's having a problem with it. Here's what he described:
"So in november, my engine died and i replaced it with a used engine (one that had under 55,000 miles). Everything's been fine with it until tonight. Now the engine is running extremely hard: when its idling (at stoplights and whatnot), the car shakes violently, while i'm driving it can be very jerky (drives fine for a bit, feels like the engine drops out, then picks itself back up again). This is pretty vague, but if anyone has any ideas as to what it could be, please let me know."
I told him it could be a number of things, but that it's probably either a fuel or air delivery problem. Also told him to to have the car scanned at autozone, and to check his MAF sensor. But I'm not familiar with corollas so I don't know if it even has an MAF sensor. Can someone give me a better reply? Thanks.
Ranger X is offline   Reply With Quote
Old 03-02-2007, 02:20 AM   #2 (permalink)
retiredat44's Avatar
View retiredat44's Photo Gallery
Question
vacuum leak??? check vacuum hoses. maybe even distributor, plug wiring,, etc.. gone bad..
retiredat44 is offline   Reply With Quote
Old 03-07-2007, 09:33 PM   #3 (permalink)
View John Sims's Photo Gallery
Gas Cap Not Tightened?
Sounds Like It By Your Description.
John Sims is offline   Reply With Quote
Old 03-07-2007, 10:07 PM   #4 (permalink)
Feel the vibe.
vibebreaker's Avatar
View vibebreaker's Photo Gallery
have him check the MAF sensor like you said.
vibebreaker is offline   Reply With Quote
Old 03-10-2007, 06:57 PM   #5 (permalink)
Proud Driver: The Defiant
joker111481's Avatar
View joker111481's Photo Gallery
I recently had very similar symptoms in a '90 corolla, and it needed a tune up (spark plugs, ignition wires, distributor cap and rotor, pcv valve, fuel filter all replaced) and also one of the fuel injectors was shot and needed to be replaced. So it couldn't hurt to check all of those things.
1990 Corolla DX: 4A-FE engine, 1.6 L
Ice Pearl Blue
"The Defiant"
Size is very deceiving...don't let her fool you. Her name is well-earned.
joker111481 is offline   Reply With Quote
Old 03-11-2007, 03:37 PM   #6 (permalink)
View aarong420's Photo Gallery
check your TPS as well..
aarong420 is offline   Reply With Quote
Old 03-12-2007, 08:49 AM   #7 (permalink)
All-Trac Guru
ghost_ryder35's Avatar
View ghost_ryder35's Photo Gallery
those vaccum leaks can cause crazy idling issues. Spray some soapy water on the vaccum lines, if you see some bubbles, then you got some leaks . TPS (like aaron said) could be causing the dropping out while driving and then picking back up symptom, can pick a used one up at the junk yard for a little cash.
89 Corolla All-Trac Sedan White 188,xxx (Sold)
89 Corolla All-Trac Wagon Blue 172,xxx (Current)
ghost_ryder35 is offline   Reply With Quote
Does your engine make this sound when cold? montreal 9th Generation (2003-2008) 69 05-05-2009 08:10 PM
interesting article about double clutching boroEF Hardcore Tech and Competition 40 07-23-2007 01:12 AM
Toyota 80 series high idle speed on startup redkat Land Cruiser Forum 1 01-03-2007 11:35 PM
stuttering and stalling with rough idle kurzawa Camry & Solara Lounge 0 08-20-2006 07:20 PM
99 Tacoma 2.7 rough idle greg 79 f150 1st Generation (1995.5–2004) 8 03-10-2006 04:37 AM
