How hard is it to replace Steering Rack on 1989 Corolla? - Page 2 - Toyota Nation Forum : Toyota Car and Truck Forums
Old 04-02-2007, 02:51 AM   #16 (permalink)
retiredat44's Avatar
View retiredat44's Photo Gallery
Exclamation
Still hoping the rack holds out, sometimes it feels bad.. but here another really good website with a page of info, about 'Steering Rack Morning Sickness':
http://www.forparts.com/ICpowersteeringleakt5.05.htm
the Rack it is in the worst possible place, almost totally impossible to get out of the car...
probably must be up on a hoist...
the labor would be a huge amount of money,,,
it would be extremley easy to replace if it were easier to get to.... I could do it in 20 minutes with my eyes closed in the open..
retiredat44 is offline   Reply With Quote
Old 04-02-2007, 03:02 AM   #17 (permalink)
Exclamation
More info on replacing a PS Rack, well actually having a shop do it:
http://en.allexperts.com/q/Toyota-Re...ack-Pinion.htm
Question
I have a 1986 Toyota Camry. I realize this is an old car but bear with me. How much would it cost for a new rack and pinion? How many hours of labor does this require from the average mechanic? Finally, my A/C needs to be recharged. Given the age of the car will I need a whole new system? In either case, how much will this cost? I appreciate your help.
Answer :
I don't like to give repair estimates because of geographical considerations, in other words, it depends on where you live.
I'll give you an estimate of what it would cost in southern calif. it should be cheaper anywhere else anyway.
The labor rate to replace the power steering rack is about 4 hours, multyplied by the shops hourly charge, around here
this translates into about $320 it should include an alignment, an aftermarker steering rack will run about $250.
As far as the a/c is concerned I recommend that you change the system over from the R-12 freon, which costs about $55 a pound to R-134 freon at about $6 a pound,your system requires two pounds of freon, the changeover kit is around $50 available at most autoparts stores(Autozone, Kragen,Pep boys, etc.,)may be a little higher if it comes with the freon, if it doesn't, buy a recharging kit along with the retrofit kit, and you can do this yourself, just follow the instructions, this should get it up and running again.
http://wiki.answers.com/Q/What_are_i...7_Toyota_Camry
What are instructions for and how difficult is it to replace rack-pinion steering on 4cyl 1997 Toyota Camry?
Answer :
This is not a simple job.It takes about two hours just to remove it,and I would not attempt it without putting the car on a lift. My advise:take it to a mechanic who has done it before......
(Note: I realize this is about a Camry, but close enough)
Old 04-02-2007, 05:41 AM   #18 (permalink)
Exclamation
Has anyone tried TransX in their Power Steering?
Corolla brakes/Paseo strut. Donald Tercel, Paseo, Starlet, and Sera Forum 35 09-13-2007 11:13 PM
Replace rack and pinion 1996 Avalon TMack409 1st Generation (1995-1999) 2 02-12-2007 03:34 PM
1989 Toyota Corolla SR5 Missing Bolt/thingy retiredat44 General Discussion 0 06-11-2006 04:18 AM
Stealership wants to replace rack & pinion - 2003 LE w/ 55K bcnland 5th & 6th Generation (2002-2006 & 2007-2011) 8 10-08-2005 09:37 AM
How hard is it to convert to power steering? Camdaddy MR2 Forum 21 10-13-2004 09:29 PM
