Originally Posted by cmoore99
I just picked up an '04 Corolla LE for my daughter to drive. The body, engine and automatic transmission are all in good shape. Fluids are all fresh. I have also checked the front brakes and they still have some pad life left. I have yet to check the rear brake shoes. The car also came with all but new Bridgestones. The car has 75000 miles. Now my question for the forum. Any maintenance items other than regular oil changes that I need to worry about? Timeing belts, fuel filters etc...Thanks in advance for any help and direction you can give me.
Charlie M.
Dallas, Texas
I have an 03S with 66K on it...basically the same car as yours...
My rear brakes are still original and when checked last fall I had 50% pad left, I just put my third set of front pads(ceramics) on...With ceramics I don't get that morning pad squeal from being damp
The previous owner should have a list of items he has done through regular maintenance under warranty, I think you can even check through your cars vin number...
Whenever I buy a used car I like to start fresh and give it a complete fluid change, oil/coolant/tranny/break fluid etc etc,...then you have peace of mind to know its done and then start keeping your own records...
Check/replace filters air and cabin(under glove compartment) fuel filter is built in the fuel pump in the tank...also the timing chain is a chain no need to replace at 75K unless its making noise, also important is to check your serpentine belt for wear/cracks...
Few other things, Every early summer I get a wheel alignment and wheel balance/ rotation from winter wear...Also check your battery...
I probably missed some that maybe others can help with here...
Last tip, if your handy then DO IT YOUSELF and save big $$$$ over what the dealer and others might charge you, your daughter has a great reliable car
Good Luck
~Radd
