Help Please! - Toyota Nation Forum : Toyota Car and Truck Forums
Old 03-07-2007, 09:24 PM   #1 (permalink)
View John Sims's Photo Gallery
Help Please!
I Need Help.
My Friend's 2005 Corolla "Maintenance Required" Light On. There Is A Grinding Noise When You Start The Vehicle And A Similar Noise When You Accelerate. There Is No Under Carriage Damage.
Any Ideas On Where To Check?
Thanks In Advance.
John
John Sims is offline   Reply With Quote
Old 03-07-2007, 09:31 PM   #2 (permalink)
ems
View ems's Photo Gallery
The maintenance light is just telling you that you need to change the oil. You can turn the light off by yourself. You need to be more specific about the grinding noise. Does it sound like the starter is grinding and turning on by itself when you are driving. Does it sound like the same noise when you start the car.
ems is offline   Reply With Quote
Old 03-07-2007, 09:41 PM   #3 (permalink)
The Grinding Sounds Similar When I Had A Loose Plate Under My Infiniti.
It's Got Roughly 30K Miles So Major Engine Problems I Doubt.
The Grinding Is Like Something Is Rubbing Against The Bottom. Painful For Me To Hear.
So "Maintenance Required" Is Just The Oil? Not Brakes, ATF Fluid, Ect.
Thanks In Advance.
John
Old 03-07-2007, 09:46 PM   #4 (permalink)
You Mentioned The Starter. She Claims She Hears The Tires But She's Insane Because It's Not That.
I Figured A CV Joint But That Wouldn't Explain It Grinding At Start.
Old 03-07-2007, 09:54 PM   #5 (permalink)
ems
Maybe a loose heat shield but this is hard to diagnose without actually hearing the noise. I'm not sure what it could be.
Old 03-07-2007, 09:56 PM   #6 (permalink)
Where Is The Heat Shield Located? In Front Of The Dash?
Could You Please Describe It?
Thanks.
John
Old 03-09-2007, 04:20 PM   #7 (permalink)
Amber's Avatar
View Amber's Photo Gallery
Isn't the vehicle still under warranty? If so, let the stealer figure it out.
2004 Corolla LE - 5 speed, leather, sunroof, spoiler, fog lights, alloy wheels
600 Mile Club - Founding Member
My FD - 335 hp - ~2800 lbs with me in it!
Amber is offline   Reply With Quote
Old 03-10-2007, 12:52 PM   #8 (permalink)
Donald's Avatar
Gameroom cash: $201420
View Donald's Photo Gallery
Alternator bearings possibly?
loose belts?
Open the hood and have someone else start the car and see if you can isolate the area the noise is comming from.
'88 Corolla, AE92 SR-5, 7A-FE swap/GT-S suspension
'87 Corolla, AE82 FX-16, 4A-GZE swap (autocrosser)
'03 Tundra 4X4 Access Cab, (FX tow vehicle/Home Depot runner)
Modification: Changing something to what you thought it should have been from the start!
Donald is offline   Reply With Quote
Old 03-10-2007, 05:01 PM   #9 (permalink)
ΜΟΛΩΝ ΛΑΒΕ
falnfenix's Avatar
Gameroom cash: $489401
View falnfenix's Photo Gallery
agreed. provided the girl's been doing routine maintenance, they should cover it.
ಠ_ಠ
i don't play well with others.
falnfenix is offline   Reply With Quote
Old 03-12-2007, 04:04 PM   #10 (permalink)
07 Corolla
Jonny Steele's Avatar
View Jonny Steele's Photo Gallery
Starter shaft broken, it slips when you try to start it, and its riding on the flywheel when you accelerate because the slight torque of the motor makes it rub, same thing happened to mine.
Jonny Steele is offline   Reply With Quote
