thudding at slow speeds - Toyota Nation Forum : Toyota Car and Truck Forums
Old 03-08-2007, 01:27 AM   #1 (permalink)
Napa Burgundy '98 Avy
View cexsiman's Photo Gallery
AE92 thudding at slow speeds
I first got the drivers side axle/cv replaced on my corolla, and I just got the passenger side cv joint and axle replaced on my car like 500 miles ago and now i dont know if its related or not there is a thudding on the dirvers side of my 1992 corolla. it basically sounds like i am driving over reflectors in the road at high speed when i am going like 20 in a parking lot. it does it while turning a little bit. its been getting worse even though i havent put many miles on it since. i think i remember hearing it for the first time after hard(ly, lol) acceleration there was kind of a loud thud, but i didnt go over any bumps or hit anything. its an automatic and if i throw it in neutral it still does it, so i know my tranny is fine, i have toyed around with the idea that it might be the struts, but i dont know if it would be that or maybe the wheel bearing? and the only reason i think bearing is because i didnt realize my drivers cv boot was basically off for like 4k miles. i dont know what a bad bearing sounds like or looks like for that matter because i have never really dont much work on my car personally. any input would help me find a place to start. i have been looking for struts and springs just because i want better road handling, but i dont have the extra for it until after its all fixed and fine. thanks for reading my long post.
cexsiman is offline   Reply With Quote
Old 03-08-2007, 04:45 AM   #2 (permalink)
ΜΟΛΩΝ ΛΑΒΕ
falnfenix's Avatar
Gameroom cash: $489401
View falnfenix's Photo Gallery
check your tires and the bolts attaching the struts to the mounts...the mounts are the big round things with 3 bolts on either side of the engine bay. sounds like the bolts MAY be loose.
ಠ_ಠ
i don't play well with others.
falnfenix is offline   Reply With Quote
Old 03-08-2007, 03:15 PM   #3 (permalink)
Question
tired that, didnt change anything, and those bolts were tighter than a mofo. i even looked around and tightned everything that i could get to with a ratchet, everything under the hood was really snug, i will try and check the bolts on the bottom of the strut but i highly doubt those are loose. again its a very loud and distinctive sound and feeling when at a low speed.
i've been asking around, and so far no one has a clue.
Old 03-08-2007, 05:04 PM   #4 (permalink)
ΜΟΛΩΝ ΛΑΒΕ
falnfenix's Avatar
tie rods?
ಠ_ಠ
Old 03-09-2007, 11:01 AM   #5 (permalink)
View tashirosgt's Photo Gallery
cexisman,
You said the thudding was like driving over reflectors. Is it regular like thud..thud..thud? Or is there just a thud every now and then?
tashirosgt is offline   Reply With Quote
Old 03-09-2007, 12:15 PM   #6 (permalink)
AE92
the thuds are regular, and consistent, like reflectors, its about as harsh and as frequent as going over a line of them at 15-20mph or so.
is there a way for me to check my tie rods? would it be a visible or noticable difference between the both sides? or if it is a tie rod, possibly a bushing, would i only be able to tell while there is stress on it, like while it is moving?
Old 03-09-2007, 12:22 PM   #7 (permalink)
retiredat44's Avatar
View retiredat44's Photo Gallery
Exclamation
put the car up on a jack and spin the front wheel(s). Also yank back and forth, feel for play....
take your time, do it for a while, see if it repeats. Also drive the car for a couple miles first to make sure the car and wheel is warm before you do this..
good luck..
could be the half axle joint, or even a wheel bearing..
retiredat44 is offline   Reply With Quote
Why Must It Be So Slow TTercel Off Topic 5 08-01-2006 11:43 PM
slow forum since last weekend...... subliminaltrips 89-95 Toyota Pickup/Hilux 6 03-04-2006 11:57 PM
1990 Camry thermostat slow to warm up, slow to go into overdrive 38dean 1st & 2nd Generation (1983–1986 & 1987-1991) 2 10-09-2004 02:11 AM
