Clutch Replacement 96 Corolla - Toyota Nation Forum : Toyota Car and Truck Forums
Old 03-08-2007, 10:40 AM   #1 (permalink)
View fsds123's Photo Gallery
Any advice/tips on replacing the clutch? Anything else I should replace while the tranny is off? I've done numerous clutch jobs on FWD VW's, but this is my first Toyota. Am going to replace clutch, pressure plate, throw out bearing, and main rear seal. Missing anything? Any tips on getting the tranny off and on? Also, are there any Toyota sites with more info? I guess I was spoiled by vwvortex.com, but this board doesn't seem to have even 1/1000th the info I can find for VW's.
Thanks
fsds123 is offline   Reply With Quote
Old 03-08-2007, 10:46 AM   #2 (permalink)
All-Trac Guru
ghost_ryder35's Avatar
View ghost_ryder35's Photo Gallery
You listed everything I would replace! Just a side note, Toyotas are way easier to work on than VW's (i've had a few Jettas ) The link at the top of the forum has a whole bunch of FSM's that would probally be usefully to you. http://toyotanation.com/forum/t62504.html
89 Corolla All-Trac Sedan White 188,xxx (Sold)
89 Corolla All-Trac Wagon Blue 172,xxx (Current)
ghost_ryder35 is offline   Reply With Quote
Old 03-08-2007, 03:51 PM   #3 (permalink)
View toyomoho's Photo Gallery
Might get the flywheel resurfaced and check the ring gear for any bad teeth etc that may lead to starting issues down the road.
Old 03-08-2007, 10:28 PM   #4 (permalink)
Thanks for the replies. Wow, just took a better look underneath. Looks like you have to remove the entire subframe, and part of the exhaust. Does the control arm need to come off ? Steering rack?
Don't know if I agree about it being easier than a fwd vw...i could do a clutch job in 3 hours start to finish...no subframe, exhaust, control arm or steering to mess with. I'll let you know how it goes this weekend.
Any more hints to make it easier...like taking stuff off that gets in the way?
Old 03-11-2007, 08:17 PM   #5 (permalink)
Finally finished. Man what a pain, but at least it's done. Biggest pain was not being able to get the drive shafts to come off, so I had to remove them at the boots. That and having to lift the tranny up by myself.
History of the Corolla Ratko Corolla Lounge 26 06-16-2010 04:20 AM
1990 4cyl manual clutch replacement? hxcgary 89-95 Toyota Pickup/Hilux 12 05-03-2010 02:02 PM
clutch slipping after clutch master cyl + slave cyl replacement? msingletary Pre-88 Toyota Pickup/Hilux 3 03-15-2006 02:01 AM
Clutch replacement question... jermag24 Camry & Solara Lounge 3 08-05-2005 05:23 PM
Can you adjust the clutch pedal on 1999 Corolla? 67mike Archived Corolla threads 0 02-10-2003 11:00 AM
