Having Clutch problems. - Toyota Nation Forum : Toyota Car and Truck Forums
Old 03-09-2007, 09:03 PM   #1 (permalink)
View Prizm_POS's Photo Gallery
I just bought a 92 geo prizm. same as corolla. and im having some clutch issues. today i was driving around and i go to stop but 2nd gear wont disengage. and my car dies..i force it into neutral, start it back up and go to put it in first with the clutch to the floor and it grinds..i pump the pedal and i feel that im getting more pressure. and it drives fine. but i have to keep doing that to get in the next gear...
what could be wrong?
Prizm_POS is offline   Reply With Quote
Old 03-10-2007, 04:39 PM   #2 (permalink)
View Hemi3TC's Photo Gallery
The clutch master or clutch slave are leaking. Check your fluid level to see if it is going down and behind the boots on the master and slave for fluid.
h3tc
Hemi3TC is offline   Reply With Quote
Old 03-10-2007, 04:51 PM   #3 (permalink)
View nsiqui10's Photo Gallery
check linkages at slave cylinder, as ^^^ he said check fluid leaks, check pedal freeplay between the linkages and the clutch master cylinder
YEeEAa
nsiqui10 is offline   Reply With Quote
Old 03-10-2007, 05:50 PM   #4 (permalink)
I check on the firewall to see if the master cylinder was leaking, and nothing was wet or slimy. I dont know if the slave is leaking just yet.
i think im going to just replace both of them and if that doesn't help, what would it be?
Old 03-10-2007, 06:45 PM   #5 (permalink)
The clutch master would not show that is leaking at the firewall. The actuator rod from the clutch pedal is where you would look inside of the boot or at the rod if the boot is filled up and leaking at the hole.
h3tc
hays brute clutch - new in box - 22re 4runner pickup dcg9381 Car Parts for Sale 1 11-29-2006 09:53 PM
clutch pedal problems Bill Gardner 89-95 Toyota Pickup/Hilux 2 04-20-2006 07:50 AM
Soft Clutch + Can't shift into / out of gear !! noobiedoobiedo Camry & Solara Lounge 6 03-20-2006 08:21 AM
91 mr2 clutch problems scandelous MR2 Forum 2 12-30-2004 05:31 AM
Clutch problems dafunk_80 Celica Forum 1 12-20-2004 07:07 PM
