Whoops. I was assuming 06 or older.
Your constant wire is going to be black @ the ignition harness (larger gauge than the others)
The door trigger gets a bit tricky. There is a separate wire for each door. Some people would think you could just wire the wire to all 4 door trigger wires. You do, but you have to diode isolate each wire to prevent the opening of one door telling the BCM that all 4 doors are opening.
The LF door is blue at the BECU, 26 pin plug, pin 24. The RF door is yellow at the BECU, 28 pin plug, pin 21. The LR door is lt. green at the fuse box, R side, 13 pin plug, pin 7. The RR door is gray at the BECU, 28 pin plug, pin 5 or 7
Save the MT: "We like real manual transmissions. Please don't kill them."
