where does the horsepower go? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 03-15-2007, 02:34 AM   #1 (permalink)
View Michaelv's Photo Gallery
howdi guys another amature as post from mikeee
Alright, supposedly my stock 1600cc makes about 103Hp, a mate told me that quite a bit of horsepower is taken up by the belt driven water pump and that installing a battery operated pump could spare me a few more horses! what do you felers reckon about this?
Mikeee
Michaelv is offline   Reply With Quote
Old 03-15-2007, 02:40 AM   #2 (permalink)
Resident asshole
Flashmn's Avatar
Gameroom cash: $352045
View Flashmn's Photo Gallery
Wont make a a difference with a small waterpump such as in a corolla.
Old 03-15-2007, 04:00 AM   #3 (permalink)
The TN Member
View punter's Photo Gallery
I would consider it on a race car, with a worked engine, as you would spend alot of time very high in the revs. (And an electric pump system is better at cooling).
But on the street its not work the hassle, and unless you've already done alot of work to your engine you shouldn't even be thinking about it.
Say no to huge pics as signatures.
punter is offline   Reply With Quote
Old 03-15-2007, 09:41 AM   #4 (permalink)
Vroom?
freakinbox's Avatar
View freakinbox's Photo Gallery
Well it's not gonna hurt the hp rating by getting rid of things like power steering, a/c and the water pump. But it's not gonna give you as much power as if you were driving a v8.
It's like on a rwd it helps to put an electric fan
1989 Corolla sr5, 4af, 1990 gts seats, TRD short shifter.
http://www.cardomain.com/ride/2061750
freakinbox is offline   Reply With Quote
Old 03-15-2007, 10:09 AM   #5 (permalink)
KDM is in
REN69's Avatar
Gameroom cash: $273221
View REN69's Photo Gallery
Get rid of your power steering and brakes dude.. who needs them when you can tie ropes to the wheels to control the turning, and just do what Fred Flinstone does to brake... that should give you the whole 2hp you're losing.
Old 03-20-2007, 06:17 PM   #6 (permalink)
View 96_9c1's Photo Gallery
How is it better at cooling?
An electric water pump, pumps the same amount it does at 1000rpm as it does at 5800 rpm, but a mechanical pump will flow more or less depending on the rpms.
96_9c1 is offline   Reply With Quote
Old 03-20-2007, 09:35 PM   #7 (permalink)
Vroom?
freakinbox's Avatar
I would assume the electic pump would need a sensor to work properly
Old 03-21-2007, 12:40 AM   #8 (permalink)
Resident asshole
Flashmn's Avatar
No, it would need 12V to work properly...
problem with mechanical pumps is that they cavitate on high rpm.
Old 04-17-2007, 08:30 PM   #9 (permalink)
The TN Member
Bingo!
That and the fact that at high RPM race applications, the water is flowing so fast that it doesn't spend enough time in the radiator to cool down, Causing overheating.
Also an electric pump can regulate the temp better, most electric setups I've seen don't run a thermostat, they just use the pump to regulate the temp.
Old 04-17-2007, 08:34 PM   #10 (permalink)
2005ToyotaCorollaS
View daniel2002p's Photo Gallery
the whole belt driven stuff takes up about 10hp or around there.... put a exhaust and intake on it will give u same result...
D
What do the mlm gurus know that you don't?
Find out how they play by a different set of rules
than everyone else... and... how your company
teachings are actually causing you to fail!
http://www.financialfreedomfordummies.com
daniel2002p is offline   Reply With Quote
Old 04-17-2007, 10:34 PM   #11 (permalink)
BANNED
View w203's Photo Gallery
D
Debatable, for the XRS I would believe that adding an intake and exhaust would yield 10hp or more but not on his Corolla. The belt driven accessories do cause parasitic loss but at the expense of the things that makes the drive more convenient (ie P/S, A/C etc). Its a good way to squeeze out as much power as possible but there will be a tradeoff.
w203 is offline   Reply With Quote
Old 04-18-2007, 08:29 AM   #12 (permalink)
Resident asshole
Flashmn's Avatar
I wouldnt bother removing the powersteering, A/C doesnt cause practically any drag when the magnetic clutch is disengaged. Even modern race cars have powersteering.
Old 04-18-2007, 01:41 PM   #13 (permalink)
BANNED
Only because the people who could afford them don't want to deal without the ammenaties that makes the drive easier. Pansies
Old 04-18-2007, 02:10 PM   #14 (permalink)
View toyomoho's Photo Gallery
The electric motor for the water pump will need power from some place, this being the alternator that is driven by the engine.
Might save some energy if the electric motor is very efficient and can vary its RPM to meet the coolant flow requirements more accurately then a belt driven pump. And thus require less overall energy.
Old 04-18-2007, 05:02 PM   #15 (permalink)
Resident asshole
Flashmn's Avatar
tangerine, not really... with extreme caster angle, your streeting gets so hard that without powersteering its close to painful to turn the car. Then again with those caster angles you can get the car to steer alot faster.
Check out rally cars, alot of them have powersteering already.
Automakers' Horsepower Ratings Drop Due to Stricter SAE Rules dsmnick General Discussion 48 01-30-2011 10:58 PM
Least Expensive Horsepower Increase?? KJSPRO 5th & 6th Generation (2002-2006 & 2007-2011) 36 04-07-2007 09:10 PM
whats faster? automatica cars with the same hp as maunal cars? TravisAe86 General Discussion 59 11-10-2006 06:21 PM
Royal Purple Oil adds horsepower and torque? TigerRaptorFX General Discussion 15 06-17-2004 08:29 PM
99 Camry Horsepower xmakavell1 Camry & Solara Lounge 4 03-02-2004 09:25 PM
