Timing belt tensioner adjust stuck - Toyota Nation Forum : Toyota Car and Truck Forums
Old 03-16-2007, 12:24 PM   #1 (permalink)
View cam76034's Photo Gallery
In the middle of a water pump replacement morphed into timing belt job. Haynes & AZ say to loosen the belt tensioner and move it to the left to take the belt off. Is this the 14mm bolt in the middle of the tensioner pulley? Cause mine won't budge and I want to make sure this is the right way to loosen it before I start breaking things.
cam76034 is offline   Reply With Quote
Old 03-16-2007, 12:58 PM   #2 (permalink)
View pgates's Photo Gallery
no.....do not pull that out. the tensioner you are looking for should be on a swivel. you can pull the staionary one if ya want but good luck getting that thing back on once you are done.
pgates is offline   Reply With Quote
Old 03-16-2007, 01:11 PM   #3 (permalink)
Registered User
Raddman's Avatar
View Raddman's Photo Gallery
USA
You didn't say what year you had...
This is for 03-07 models...
Raddman is offline   Reply With Quote
Old 03-16-2007, 01:13 PM   #4 (permalink)
Registered User
Raddman's Avatar
BTW it shows to pull it to the right not the left!
Old 03-16-2007, 01:23 PM   #5 (permalink)
Thanks, figured it out. It's the timing belt tensioner on a 90 Corolla, apparently a gorilla at the factory tightened it but I got it loose.
Old 03-16-2007, 01:23 PM   #6 (permalink)
My Timing Belt Job (Pics) 56k go away Ken4 Camry & Solara Lounge 113 05-18-2011 09:06 AM
84 Supra 5MGE Timing Belt replacement sasksupra Supra Forum 5 11-30-2005 05:03 PM
Here is a way to check timing belt. shanzhu1 Camry & Solara Lounge 4 11-23-2005 10:25 PM
Changine Timing Belt..Found Oil behind Timing Covers A2brb Camry & Solara Lounge 11 11-14-2005 04:10 PM
