new to me corolla idles high - Toyota Nation Forum : Toyota Car and Truck Forums
Old 03-22-2007, 04:02 PM   #1 (permalink)
View gus310's Photo Gallery
hey guys, im new to this forum, my 87 4runner just died, and i use it as a daily driver for my jeep project, so i am parting it out to buy an 89 corolla coupe. i have the car, the trouble is it idles real high. like 2300 rpms high. i cant figure out how to adjust it.
also, the kid i bought it of of stuck a trueno ram air hood, and front bumper on it for looks and put on some dumb 4" air ilter that isnt worthy of a power wheels. around 4500 rpm, if im pushing it, it can pop and sputter for a second. could this be a vaccuum issue with the silly filter, or maybe its getting too much air?
thanks for any help!
EDIT*** it has the carbureted 1.6l 4af motor
gus310 is offline   Reply With Quote
Old 03-22-2007, 04:21 PM   #2 (permalink)
Banned
View DougDangger's Photo Gallery
Check the air filter.
Adjust the idling with a screw driver on the throttle body.
Chances are there's a vaccum leak and they purposely raised the idling so that the roughness won't show.
Check the vaccum hoses for leaks.
Also, make sure the engine is warm when you check. Cold engines tend to idle high.
DougDangger is offline   Reply With Quote
Old 03-22-2007, 08:04 PM   #3 (permalink)
the engine is carbureted, not tbi, where on the carb is the idle adjust screw. there are two screws with springs on the passenger side of the carb, i tried turning those a bit, but they didnt do anything, where else might i look for the adjuster? ill post up pics of it tomorrow.
saturday im trading the kid for the stock hood and bumper, and picking up the title. i plan on finding out if he has the stock air filter. ill also check the vaccuum lines. the car idles high even after i drive it home.
also, sometimes, the car will idle funny and rev a bit, going from about 2000 rpms to 2300, then drops to 2k and back to 2300 etc, any ideas? i think the hondas do that when the thermostat is dying. my 22re in my 4runner did that a bit and topping off the coolant and replacing the lower radiator hose fixed that. i have a spare thermo and can top off the coolant, might that have anything to do with the high idle? or could the revving be something different?
Old 03-22-2007, 11:22 PM   #4 (permalink)
Danno
View 89yotarollagts's Photo Gallery
^ you got Private Message
"True car enthusiasts are open-minded to everyone's creation"
"Straight Roads are for Fast cars... Curvy Roads are for Fast drivers "
89yotarollagts is offline   Reply With Quote
Old 03-22-2007, 11:51 PM   #5 (permalink)
All-Trac Guru
ghost_ryder35's Avatar
View ghost_ryder35's Photo Gallery
sounds like a vaccum line problem. spray some soapy water on them and look for any bubbles. replace as nessesary.
89 Corolla All-Trac Sedan White 188,xxx (Sold)
89 Corolla All-Trac Wagon Blue 172,xxx (Current)
ghost_ryder35 is offline   Reply With Quote
Old 03-23-2007, 10:37 AM   #6 (permalink)
KDM is in
REN69's Avatar
Gameroom cash: $273221
View REN69's Photo Gallery
This is not Aaron's car is it?? painted flat black?
Old 03-23-2007, 04:35 PM   #7 (permalink)
thats right, you local? or is he on this forum?
Old 03-23-2007, 05:45 PM   #8 (permalink)
where on this carb should i look for the idle adjust screw, is it in the linkage, or on the body?
also, is ther a power steering conversion i can do to this car? something easily swappable from another model, or a bolt on kit or anything? i might like to have power steering in it.
Old 03-24-2007, 07:54 AM   #9 (permalink)
Gameroom cash: $150700
View 90 GP's Photo Gallery
The idle adjustment screw is near the black choke housing on the back side of carb. It is a long screw that sits at an angle and has a large head with groves around the edge. In addition to lowering idle you might want to look for vacuum hose leaks. Particularly pcv hose as it is large and sits low in manifold area to subject it to high heat to deteriorate it.
90 GP is offline   Reply With Quote
Old 03-24-2007, 03:27 PM   #10 (permalink)
i drive a 92mph monster
ae92Rolla89's Avatar
View ae92Rolla89's Photo Gallery
hey what kind of filter is that? with that can i replace the ugly black thing ?
1989 Corolla SR5 - caught fire...
2003 VW gti 1.8 t
ae92Rolla89 is offline   Reply With Quote
Old 03-24-2007, 03:35 PM   #11 (permalink)
sorry for the big pic
2003 VW gti 1.8 t
Old 03-24-2007, 04:20 PM   #12 (permalink)
talked with aaron today and i think i got the idle issue squared away.
Old 03-24-2007, 04:46 PM   #13 (permalink)
omg jdm
aaron7's Avatar
View aaron7's Photo Gallery
Yah that was my baby... put the front end back to stock today... what fun that was :p
I'll do some calling around for a stock intake setup. I wanted a filter like that one to sit under the scoop, and all I could clear was a 4" one!
89 MR2 MK1.5 - endless project. shiny, check. fast... almost installed...
74 CB360 - Lots of cool cafe stuff
98 Jeep GC 5.9 - Mopar intake, Mopar ECU, H&R springs, a/d/s speakers & amps, 3 JL W3
aaron7 is offline   Reply With Quote
Old 03-24-2007, 10:19 PM   #14 (permalink)
retiredat44's Avatar
View retiredat44's Photo Gallery
Exclamation
4AF Carb pics from mine:
http://virtualairforce.byethost11.co...yota/ulthm.htm
On your pics , do see the hose, with the hose clamp, off the valve cover that doens't go anywhere on your engine? that should go to the air cleaner stuff. Did he plug yours, or was it left open?
retiredat44 is offline   Reply With Quote
Old 03-24-2007, 10:32 PM   #15 (permalink)
omg jdm
aaron7's Avatar
It was left open. If you plug it the crankcase builds pressure.
2007 Corolla Information (Corolla XRS R.I.P) silver04rollas Toyota News 111 08-27-2007 03:17 PM
I Need Your help on a 2003 Corolla LE- unbelievable story Smittay Archived Corolla threads 12 08-05-2006 08:49 PM
List of Toyota CEL Codes Marc M 2nd Generation (2005+) 0 03-29-2006 11:01 AM
