Questions about 4AGZE - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-18-2002, 12:53 AM   #1 (permalink)
View [sPooN] aE86's Photo Gallery
got a few questions..
1) can i use everything from a SC aw11 on the GTS? like ecu and can i use the harness from the 4AGE?
2) if i don't want to cut a hole in my hood cuz of the intercooler on top... what can i do to rearrange the intercooler? and where will i find these parts?
3) what else would i have to worry about?
4) is 1700 for a 13B considered cheap?
[sPooN] aE86 is offline   Reply With Quote
Old 01-18-2002, 12:54 AM   #2 (permalink)
oh yeah thanks in advance!
Old 01-18-2002, 04:40 PM   #3 (permalink)
DriftStar.com KingPin
View driiift_hachiroku's Photo Gallery
Answer to your questions:
Yes you can use everything off the MR2 SC, but you must cut and splice in more wire to extend the harness. Some people say it's more practical to use a stand alone engine management system since all of it is going out anyway.
You have to fabricate some intercooler piping to front mount the intercooler, as well as turn the throttle body elbow forward and the SC outlet pipe forward.
If you wanna take a look at my setup... you can check it out sometime when I get it back on the road in the spring.
Jover
driiift_hachiroku is offline   Reply With Quote
Old 01-18-2002, 04:44 PM   #4 (permalink)
Other things to consider...
-custom bracket for power steering pump, or delete power steering
-water pipes
-vaccum lines
-throttle cables
-external thermostat housing
-relocating your windsheild washer tanks
-fuel pump
-engine brakets to sit engine lower to clear strut tower brace
Jover
http://www.driftstar.com
1985 AE86 Corolla GTS Coupe
4AGZE (Supercharged)
Old 01-20-2002, 07:08 PM   #5 (permalink)
thanks jover!
i was wondering where would be a good place to make the pipe for the intercooler and can i just make my own vacuum lines using stuff from home depot?
Old 01-20-2002, 07:56 PM   #6 (permalink)
Banned
View goodcookiedrift's Photo Gallery
any mechanic who can tig weld should be good enough to make an intercooler pipe. It just all depends on price.
yup, you can get vacum line from crappy tire.
Nick
goodcookiedrift is offline   Reply With Quote
Old 01-21-2002, 02:58 AM   #7 (permalink)
you don't really have to fabricate much with the vaccum lines, just a few feet for the boost guage and the ABV modification if you're going to run higher than stock boost. (See MR2SC.COM)
Even a muffler shop can help you make some IC pipes.
Old 01-21-2002, 10:54 AM   #8 (permalink)
cool! now all i need is to find a 4agze... hehe
so the cheapest way is to use the ZE ecu?
Old 01-21-2002, 09:15 PM   #9 (permalink)
Turbo-Yota power
Jzs147-RR's Avatar
View Jzs147-RR's Photo Gallery
ya for sure its cheaper but more of a paine in the butt when it comes to extending the wires and sh**.
5sfe powered turd ...
Jzs147-RR is offline   Reply With Quote
Old 01-21-2002, 09:26 PM   #10 (permalink)
View fatredcircle's Photo Gallery
why would extending the wiring harness be a pain or hard to do?
its simple, crimp to crimp
crimp to crimp
crimp to crimp
wire to wire
they are all colour coded, its not like you gotta figure out what they do, you just gotta extend wires!
It'd be a lot easier than going to a stand-alone, think about it. with a standalone you gotta figure out what wires are what, and then connect them accordingly to the ecu.
if you really wanna wrig it, you don't even have to get it to go into the actual cabin, just bolt the ecu into the engine bay, and enclose it, simple, and nothing to extend
<font size=-1>[ This Message was edited by: fatredcircle on 2002-01-21 22:30 ]</font>
fatredcircle is offline   Reply With Quote
Old 01-21-2002, 11:07 PM   #11 (permalink)
SWEET!! never thought of that!!
hmmm what can we use to enclose it..? another metal box? or would plastic melt in the summer?
Old 01-22-2002, 08:04 AM   #12 (permalink)
Banned
just use sheet metal to surround it. and keep it away from anything that produces alot of heat (ie: exhaust manifold)
if you want to go super nerdy technocraft, you could use an aluminum cover/box because aluminum resists heat alot better than stainless or steel fro that matter.
Nick
Old 01-22-2002, 10:52 AM   #13 (permalink)
hold on, you might have to worry about moisture getting into the ecu.
hmm
Old 01-22-2002, 12:44 PM   #14 (permalink)
you still have to extend wires like the ones that go to the dash, and the gas tank if you put the ECU in the engine compartment. Keep it in the passenger cabin.
Old 01-22-2002, 10:29 PM   #15 (permalink)
View neil85AE86's Photo Gallery
and if you want a really dependable system, don't just crimp, do it right, quality soldering, with one or two layers of heatsink and moisture repellant. Ya could go the extra distance like yasin and move all the relays into the cabin as well. That way ya get to here the 'click' the instant before the SC engages...cool.
Neil
Uber D.I.Y. Zenki Turbo
Squirted since '03
1994 Tercel 2dr 5spd
2003 Mazda MPV LX
neil85AE86 is offline   Reply With Quote
US 4AGZE vs J-spec 4AGZE yellow86MR2 General Discussion 4 07-06-2002 02:52 PM
MR2 4agze -4agte Soobercharger MR2 Forum 1 03-31-2002 12:36 AM
MR2 4agze -4agte Soobercharger Hardcore Tech and Competition 3 03-29-2002 11:54 AM
4agze to agte Soobercharger Archived Corolla threads 1 03-29-2002 10:55 AM
MR2 4agze -4agte Soobercharger General Discussion 0 03-29-2002 09:43 AM
