4AGZE in canada.....???? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 07-05-2003, 12:24 AM   #1 (permalink)
View SalEsh's Photo Gallery
hey does any one know were i can get one in canada i live in BC canada and want to know were to get one.... alos what else will i need to swap into my AE92 4AGE 1989 toyota corolla GTS... would i need a new or different tranny?, ECU?.. and so on...
is it very hard to swap one another? ALSO what about takin out the SC and swaping it with a turbo... what will i need for the swap... and a good turbo for it..
MY car is gonna be for the strip and also street. so any suggestions would be awsome!!
thanks for any help guys!!
Brandon
SalEsh is offline   Reply With Quote
Old 07-05-2003, 01:04 AM   #2 (permalink)
KDM is in
REN69's Avatar
Gameroom cash: $273221
View REN69's Photo Gallery
well.. check out any of the japanese engine shops in your area.. chances are they can get you a GZE for your car.. there's a few places in T.O. that will do it.
Make sure they're getting you the engine, tranny and ECU.. hopefully the wire harness is not cut.. even if you get the engine, the transmission on your GTS should just bolt on, if I'm not mistaken.. you would have to get the proper ECU though... the GTS ECU is not setup to run a GZE engine. You're looking at around $2100 and up for a GZE or a silvertop 20V with tranny and ECU in the Toronto area.. not sure about BC though... a Blacktop 20V would probably cost you a bit more.
Old 07-05-2003, 10:48 AM   #3 (permalink)
Boro Box Pilot
boroEF's Avatar
View boroEF's Photo Gallery
if u get the aw11 gze u will still have to cut the harness even if u got one that's uncut. every wire that's going to the ecu will have to be extended....not sure about the body harness...possibly those ones too because it's designed to be put in a mid engine car...ur putting it in a front engine car.
u can retain the ae92 tranny or use the tranny that came with the gze, both work...but the ae92 one is closer ratio.
with regards to ecu, u have to get the corresponding ecu to the gze u get...ie) if u got a map gze, u'd obviously need a map gze computer.
aw11 gze should run u about 800-1000 bones with tranny... ecu's shouldnt be hard to get.
as for the ae92/ae101 gze's....they get quite costly....about 900 to upwards of 1800 depending on where u go and if u want tranny/harness with it or not.
The boro guru
geocities.com/nuahs_cx my site about ae92, ef and track info
boro song
"boro boro boro
here we have a duct tape la la la
here we have an electrical tape du du du
here we have a coke can da da da
and then we have a downpipe!! boro boro boro"
boroEF is offline   Reply With Quote
Old 07-05-2003, 03:03 PM   #4 (permalink)
4A-GE's Avatar
View 4A-GE's Photo Gallery
wut's the difference w/ the aw11 and the ae92 GZE?
how come the price make huge difference? more high-tec i guess?
4A-GE is offline   Reply With Quote
Old 07-05-2003, 03:09 PM   #5 (permalink)
KDM is in
REN69's Avatar
The AW11 GZE were only 145hp and they had AFM, the AE92/101 GZE from 1990 and up, were MAP sensored and had 170hp, they're also harder to find.
http://www.toyotanation.com/forum/forumdisplay.php?f=69
Old 07-05-2003, 10:13 PM   #6 (permalink)
do you think it would be worth it to swap engines? or just rebuild mine... is there any kinda forced induction i could do to it..? (4AGE) ALSO so what kinda GZE engine would be the best...??? OR could i just get the turbo engine thats in the mr2 i dont know the engine code... would that work..? ill be one of the very very few to have a modiyfed GTS in BC.... so im kinda excited
Old 07-06-2003, 03:58 PM   #7 (permalink)
KDM is in
REN69's Avatar
The turbo MR2 engine is the 3SGTE, there's been a couple of people that have done this swap on AE92's.. very expensive though, since the engine is not a direct swap, so you would have to do custom work. Also the engine itself is expensive, so you're looking at $10,000 or more to do a 3SGTE swap.
The 1990 and up 4AGZE engines have more HP than the previous generation ones.. and they were only found on AE92's in japan.. the previous generation GZE were found on AE92's and AW11's.
Old 07-07-2003, 11:51 AM   #8 (permalink)
so does any know about just modifying the 4age engine..... turbo.. blah blah and what not..
also if and when i get this engine rebuilt, are there and kinda preformance pistons and valve springs, and what not that i should put in... i dont know any and hopefully some 1 else does
Old 07-07-2003, 12:21 PM   #9 (permalink)
TN Track day addict
View Lafora's Photo Gallery
www.google.com
type in 4AG
read
My blog
Fast and cheap won't be reliable.
Cheap and reliable won't be fast.
And fast and reliable won't be cheap
Lafora is offline   Reply With Quote
Old 07-07-2003, 05:13 PM   #10 (permalink)
Boro Box Pilot
boroEF's Avatar
Originally posted by Lafora
www.google.com
type in 4AG
read
cyril is always the man that comes up with the best answers
The boro guru
boro song
"boro boro boro
Old 07-07-2003, 05:15 PM   #11 (permalink)
TN Track day addict
well if his questios were more specific...he'd get more answers.
but since it's so broad, ppl'd have a hard time answering cuz it'd be almost similar to writing an essay
so for background info, google searches work the best IMO
My blog
