Originally Posted by gbell210
Wow.. those cluster prices w/tach have gone up in only a year time. Well if you do find one cheap, its really easy to install. 2 screws for the black bezel, and 4 for the actual cluster, then 3 wire plugs.
If you want to swap out the speedometers, its a little tougher, but just remove the front clear plastic (4 clips) then 3or4 screws for the gauge. Re-assmeble and you are done. (takes about 30-45 minutes taking your time cleaning stuff too) You'd be suprised how much dust/dirt gets back there.
Ok i am assuming that the wiring harness is already prewired into the back of the cluster...?
