Window Fix - Door Panel Removal - Toyota Nation Forum : Toyota Car and Truck Forums
Old 03-31-2007, 04:00 PM   #1 (permalink)
View Zerzil's Photo Gallery
Canada Window Fix - Door Panel Removal
Car: 2003 Toyota Corolla CE
Recently, I had the joy of my window falling off the rail on the driver's side. Great fun trying to get through the Tim Horton's drive through
I took some pictures as I went through it in case anyone needs to do the same - I like these forums, and found some information on how to attempt this, but there have been a fgew questions about the C-Ring in particular, so thought I'd give back to the board.
Step 1: Popped off the armrest pieces (2) and unscrewed the screws holding the inside door panel on. See pic below.
Step 2: Now comes the worst part about this whole ordeal. I tried the cloth method of trying to get this C-Ring off, and ended up shredding one of the dish towels from the kitchen. (love you honey!) I think I may have moved the ring with all the messing around I did with the towle, but the way I got the ring off was I wrapped a shred of towel around the end of a screwdriver (biggest one I had) and stuck it under the window crank handle (between the handle and the door). This brought it out enough that I could see the ring, and I used a very thin knife (a tiny screwdriver might work too) and pushed/bent it into the end of the ring sticking out, and pulled it out. Needlenose pliers m,ay work here also, but space is quite limited, they'd need to be tiiiiny. Now, that being said, it was frustrating, but worth the looks of the neighbors as I danced around the yard waving the tiny C-Ring in the air. WOOT!
Now, why is this ring so darned important - hard to get out? Here's what the handle looks like installed. The arrows show where the ring sits inside, and how it holds the handle crank onto the post in the door.
Ugh.
Step 3: I then removed the door panel by sharp, quick pulls around the edge to dislodge the snap-in fasteners. You don't need to rip these things out, they're not in there that well, but a sharp, firm tug will do it. Watch for falling pieces.
Step 4: To get to the window bolts, you need to remove this panel:
There was some plastic covering this, and there was no other way I could see to get at it without cutting it. I made a nice (well, not really) cut into the plastic, and then when I was done, I used wide packing tape (duct tape would work too ... nobody sees it) to stitch the two sides of the cut back together.
Under that is the rear bolt for the window, and the front one is near the front of the door. I've also shown the entire door shot, where you can see both pointed to by arrows.
Once you get the rear "service" panel off, it will look like this ...
The front bolt is hidden under here:
Those two bolts are the ones that hold the window onto the mechanism that lifts it up and down. They're bolted in place, as you can see in the pics.
My trouble was the rear one had vibrated out, and the window kept falling forward. D'oh!
Anyways. That's it. Installation is just the reverse. NOTE: When you put the inside door panel back on (the large plastic covering) - make sure you place/slide it into the top first (where the window goes into the door) and then gently bump the fasteners into place around the door. I think I may have broke off a piece the first time I tried this accidentally, not paying attention to this matter.
Oh well. Happy fixing folks. Like I said at the top this is for a 2003 Corolla CE, but may apply to other years also.
2003 Corolla w/ Sport Body Package
Zerzil is offline   Reply With Quote
Old 04-01-2007, 12:22 PM   #2 (permalink)
Danno
View 89yotarollagts's Photo Gallery
just a quick note from an autobody dude...
You see the black line going around the whole plastic liner ? This can be peeled off carefully or you can cut it with a razor... if you can cut this so most stays on the car you can peel all the plastic off & restick it with no problems... (i hope you applied some tap to the spot where you cut it open ? )
Also.. i speak from experience, if you are attempting the C clip for the first time or any time in general, make sure you put your hand behind the clip & attempt to catch the spring should it decide to "fling" off i cant count how many times ive lost those springs.. They will shoot Far & very fast & will be tricky to find if you didnt see where they went..
There is a tool made for taking these clips off, but not all of us work in a autobody shop..
i too have used the 2 methods mentioned above at home & both will work just fine..
"True car enthusiasts are open-minded to everyone's creation"
"Straight Roads are for Fast cars... Curvy Roads are for Fast drivers "
89yotarollagts is offline   Reply With Quote
Old 04-01-2007, 01:48 PM   #3 (permalink)
retiredat44's Avatar
View retiredat44's Photo Gallery
Exclamation
Thank you for this thread, lots of great information (you are several weeks late for my project though...) I learned some of this myslef, but remeber a smal bit from past projects.... but my first toyota door project occured just very recently withy my door panel replacement...
One of my car door windows or the mechanism rattles when the door is closed. When I had the panel off I tried to figure out which part of those brackets was rattling. I sprayed them with Liquid wrench. I was unsucessful. it still rattles when the door is closed.. Either it is just worn out or I screwed up and missed the part I needed to stop the rattling..
retiredat44 is offline   Reply With Quote
Old 04-02-2007, 09:27 AM   #4 (permalink)
View darcsyde's Photo Gallery
i've found out that the easiest way *for me anyways* to get those c-clips off is to use a small precision flat head, push one side off, then the other and it comes off easy
darcsyde is offline   Reply With Quote
Old 04-16-2007, 04:02 PM   #5 (permalink)
View gameguru1360's Photo Gallery
I'd consider adding dynamat extreme to those body panels to absorb most of the rattling or road noise. Just be careful not to cover up the areas where those bolts screw onto, but for the most part, it's better to put some around the edges of the speakers.
gameguru1360 is offline   Reply With Quote
Old 04-16-2007, 07:14 PM   #6 (permalink)
Question
dynamat extreme =what is that??
thanx..
Old 04-16-2007, 11:21 PM   #7 (permalink)
on full afterburner
Gameroom cash: $1347897
thanx..
Sound deadener.
Search is your friend
1993 power window short on driver side fix? steve273 3rd & 4th Generation (1992–1996 & 1997–2001) 7 07-13-2007 08:53 PM
Window Tint Noise tjg184 2nd Generation (2005+) 8 09-06-2006 12:36 PM
Power window woes loonmobile Camry & Solara Lounge 0 06-27-2006 05:47 PM
Window Troubles Your Uncle Moe Camry & Solara Lounge 7 08-25-2005 01:44 AM
2 door Camry Window Regulator Rico_S Camry & Solara Lounge 7 10-18-2004 02:45 PM
