Filling Motor mounts pros & cons - Toyota Nation Forum : Toyota Car and Truck Forums
Old 04-01-2007, 12:04 AM   #1 (permalink)
Danno
View 89yotarollagts's Photo Gallery
AE92 Filling Motor mounts pros & cons
ive been reading of a few people doing this, & since there is no aftermarket source for ae92 mounts i figured i might try this out..
i just bought all new mounts & they could be alot stiffer but is this really a good idea ?
Sure my motor wont rock as much but what else do i gain ? i am not having anymore issues since i purchased new mounts, but i drove the car without a hood & noticed there is still alot of engine rock on a hard launch... Again the only issues ive had is breaking flex pipes & this was cured to moving the flex pipe further downstream & the new mounts help..
My main worry is the chassis will be taking more of the abuse rather than the mounts soaking up the shock.. also ive read about noise issues inside the car...
So is it really worth it ? discuss !
~Dan
"True car enthusiasts are open-minded to everyone's creation"
"Straight Roads are for Fast cars... Curvy Roads are for Fast drivers "
89yotarollagts is offline   Reply With Quote
Old 04-01-2007, 01:43 AM   #2 (permalink)
BANNED
View w203's Photo Gallery
Stiffer motor mounts would help reduce wheelhops in launching. The cons would be more engine vibration that would be transfered to the cabin. It may or may not be that noticible but it will nonetheless cause more vibrations.
w203 is offline   Reply With Quote
Old 04-01-2007, 09:00 AM   #3 (permalink)
Rotary guy...
eage8's Avatar
Gameroom cash: $434650
View eage8's Photo Gallery
you also get better engine response, because it spends less time wiggling around.
if you don't mind a little vibration, I'd say go for it.
'81 BMW R65
Old 04-01-2007, 11:21 AM   #4 (permalink)
View canadiancelica's Photo Gallery
I did it in my celica and ended up putting new oem mounts back it. it was a total pain in the ass as a daily driver. The vibrations coming through the steering column was what drove me nuts.
canadiancelica is offline   Reply With Quote
pros & cons of lift types Spot shooter 2nd Generation (2005+) 3 12-17-2006 09:13 AM
NE OF U Guys considering an 07 Tundra, Help out with Pros and Cons . . robsatx 2nd Generation (2005+) 21 09-17-2006 10:58 PM
Limited Slip Differential aka LSD Pro's and Con's?? RichieRichJP Camry & Solara Lounge 8 11-20-2005 05:49 PM
XRunner Pros and Cons haggard 2nd Generation (2005+) 6 06-20-2005 08:46 PM
Pros and cons of 3vzfe and 1mzfe? Stealth 3rd & 4th Generation (1992–1996 & 1997–2001) 14 05-12-2003 10:25 PM
