4AF troubles =( - Toyota Nation Forum : Toyota Car and Truck Forums
Old 04-03-2007, 09:39 PM   #1 (permalink)
i drive a 92mph monster
ae92Rolla89's Avatar
View ae92Rolla89's Photo Gallery
AE92 4AF troubles =(
okay i have two issues...
the first one is the car.. it has an oil leak coming from the crankshaft seal or w.e but thats goign to be taken car of so i was wondering the car leaking alot of oil will tend to get hot? i was driving it around my neighborhood and it started to over heat so i stopped and let it cool down... and other thing that the car hasbeen doing is when i am driving it just tends to shut off in neutral at a stop sign the Rpms just drop to zero n the car shuts off i put it into first and accelerate and its okay once i take my foot off the acc. it shuts off... does any one have any idea whats going on with my car =(???
1989 Corolla SR5 - caught fire...
2003 VW gti 1.8 t
ae92Rolla89 is offline   Reply With Quote
Old 04-04-2007, 08:28 AM   #2 (permalink)
View tashirosgt's Photo Gallery
I don't think the oil leak will make your engine overheat if you keep refilling the oil. Are you getting signs of oil in your coolant or coolant in the oil?
tashirosgt is offline   Reply With Quote
Old 04-04-2007, 06:36 PM   #3 (permalink)
View LFAsr5's Photo Gallery
have you checked your coolant levels? and the thermostat, mine was effed and it make my car over heat. As far as your idle dropping...did you adjust the idle at all? your choke might be sticking too.
LFAsr5 is offline   Reply With Quote
Old 04-04-2007, 08:02 PM   #4 (permalink)
retiredat44's Avatar
View retiredat44's Photo Gallery
Exclamation
I suggest you be extremely careful and take note before and during any carb tuning. If you have a carb... Use a website and/or manual to guide you. Once you mess with the carb, you may not get it back to the factory settings, or a shop's settings.
IMHO
retiredat44 is offline   Reply With Quote
4af to the fe head? or 4age internals in a 4af? freakinbox Archived Corolla threads 24 04-07-2006 01:21 AM
20v head on 4af block ? FCON_VPRO Archived Corolla threads 12 03-22-2005 02:46 AM
Applying Turbo With A Stock Carb. To 4AF keremerdag Archived Corolla threads 17 12-12-2004 05:12 PM
Header for 4af drozy88d Archived Corolla threads 15 10-14-2004 11:07 PM
G head on 4AF block? Punisher Archived Corolla threads 23 03-03-2004 10:07 AM
