91 rolla brake issue - Toyota Nation Forum : Toyota Car and Truck Forums
Old 04-03-2007, 09:50 PM   #1 (permalink)
View tysn's Photo Gallery
i just installed brake pads on my corolla turned the rotors and such. we bled the brakes, had pressure in the pedel. i go to start the car to leave and the pedel goes to the floor and i have little to no brake pressure. any idea on whats up? master cylinder?
tysn is offline   Reply With Quote
Old 04-04-2007, 08:29 AM   #2 (permalink)
View tashirosgt's Photo Gallery
Did you regain brake pressure when you shut the engine off?
tashirosgt is offline   Reply With Quote
Old 04-04-2007, 07:39 PM   #3 (permalink)
brake pressure is better when the car is off but still not where is was before i replaced my pads.
Old 04-04-2007, 08:20 PM   #4 (permalink)
View toyomoho's Photo Gallery
With engine on does the brake pedal travel decrease (braking get better)? Things that cause low brake pedal are excess rear drum/shoe clearance, air in mater cylinder or brake lines, fluid leaks, worn master cylinder, brake pads sticking on anchor plate surfaces. Have someone watch the front pad braking action when pressing the pedal. Make sure the caliper pistons and pads are moving as a unit.
Old 04-04-2007, 10:18 PM   #5 (permalink)
retiredat44's Avatar
View retiredat44's Photo Gallery
Exclamation
Bleeding brakes takes practice and knowledge. Sound slike there is still air in the line... do the manual bleed mtheod with 2 people. Buy a large 32 oz. bottle of brake fluid. If you don't know the manul method, I am sure someone can expalin it. I need rest right now.
retiredat44 is offline   Reply With Quote
Old 04-06-2007, 08:54 PM   #6 (permalink)
update
ok it seems my orginal rotors were too well worn to turn, so i bought some new rotors and we proceeded to bleed the brakes. the pressure came back. we will be dong my rear shoes next week. my question is my brakes are burning after a while. wtf causes that? we cleaned the new rotors with brake cleaner. is it that crap just burning off? cause i thought that shit dried pretty fast?
Old 04-07-2007, 10:56 AM   #7 (permalink)
Gameroom cash: $150700
View 90 GP's Photo Gallery
Did you lubricate the slide bushings in the caliper to see that they operate freely? If not you may have a caliper hanging up on the rotor.
90 GP is offline   Reply With Quote
Old 04-07-2007, 11:22 AM   #8 (permalink)
All-Trac Guru
ghost_ryder35's Avatar
View ghost_ryder35's Photo Gallery
a sticky caliper would cause burning brakes.
I highly recommed http://www.northerntool.com/webapp/w...13&R=200310613 for bleeding brakes
89 Corolla All-Trac Sedan White 188,xxx (Sold)
89 Corolla All-Trac Wagon Blue 172,xxx (Current)
ghost_ryder35 is offline   Reply With Quote
91 Rolla Eng Swap fabbb Archived Corolla threads 1 11-13-2006 04:36 PM
Quick question, would rear struts off a 91 'Rolla fit my 88 'Rolla wagon? Infinitrium Archived Corolla threads 2 10-13-2006 05:00 PM
'91 brake upgrade... ryde MR2 Forum 3 03-05-2005 06:25 AM
Ford brake conspiracy EKam Hardcore Tech and Competition 19 04-02-2004 07:17 PM
