1992 stuck in park? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 04-03-2007, 11:58 PM   #1 (permalink)
View tank45's Photo Gallery
1992 stuck in park?
It's stuck in park unless I use the shift override button. Anyone might know what could be causing this?
tank45 is offline   Reply With Quote
Old 04-04-2007, 12:16 AM   #2 (permalink)
View toyomoho's Photo Gallery
Look next to the gear shifter lever on the gear indicator cover. There is usually an override button or a small cover that can be gently pried off to expose a lever you press on. Use something like a screwdriver blade.
Check to see if you have brake lights. Most of these systems use the brake light switch that can fail or get out of adjustment.
Also check the posts at the end of this page, might help get an idea of what is going on.
Old 04-04-2007, 01:47 AM   #3 (permalink)
Your assumption of the brake light was dead on, my brake light doesn't work i was just driving my friend home who lives down the street and it came on at some random times but for 99% percent of the time it was no go. So what will i need to do to remedy this situation
Old 04-04-2007, 05:15 AM   #4 (permalink)
Dave's
Gameroom cash: $124350
View Dave's's Photo Gallery
Think if you trace your brake pedal up towards the dash you'll find a switch. Either adjust it or replace it as needed.
Dave's is offline   Reply With Quote
Old 04-04-2007, 08:51 AM   #5 (permalink)
Just to eliminate anything I replaced all the bulbs in the bracket in the trunk 4 x 1156s and 4 x 1157s. Now could this have to do with a fuse problem cause about 2 days before this happend one of my instrument panel light section went out (Vent, Heater, A/C Controls)
Old 04-04-2007, 03:13 PM   #6 (permalink)
I'm having trouble finding a "92 corolla brake light switch" online is this part refererd to as something else by any chance?
Old 04-04-2007, 09:17 PM   #7 (permalink)
Try stoplight switch, see link below. www.rockauto.com lists them under electrical switches/stoplight switch.
http://www.rockauto.com/catalog/x,ca...h,partGroup,78
Is the fuse blown? Or most Toyota’s the Stop fuse is separate from the vent, heater, A/C systems. Find the switch then test it or just jump the wires and see if you brake lights now work.
Old 06-24-2007, 04:07 PM   #8 (permalink)
View Dopey92's Photo Gallery
Did you ever resolve this? was it the brake light switch at the brake pedal? I had a similar problem on my 98 Corolla. Difference was that my brake lights were working. I finally traced it to the "ignition switch". This is NOT the key & barrel. There is an electrical switch just below the key & barrel.
Good luck!
Dopey92 is offline   Reply With Quote
Transmission stuck in park johnface General Discussion 4 04-03-2007 10:49 AM
1992 Paseo JT2EL45F2N0097655 PatPend Vehicles 3 02-26-2007 02:03 PM
stuck in park? ambrew 2nd Generation (2005+) 11 11-19-2006 12:17 AM
Gear selecter stuck in park 4runlou 4Runner Lounge 3 03-21-2006 10:50 PM
Help! Transmission stuck in Park bigphil001 Camry & Solara Lounge 2 03-20-2006 04:50 PM
