how to stop oil burning? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 04-04-2007, 05:05 PM   #1 (permalink)
View tlong831's Photo Gallery
my 94 corolla burns about 1/2 a quart ever 1000miles .. what can i do to lower this consumption?
tlong831 is offline   Reply With Quote
Old 04-04-2007, 05:26 PM   #2 (permalink)
View broke's Photo Gallery
I am pretty new to the world of toyota, but 1/2 qt over 1k miles doesn't sound so bad.
As long as you are not leaving a smoke screen behind you should be ok. If it really bothers you put a can of restore in there see if that helps. If you really are burning oil time for new rings.
However this is just my opinion
broke is offline   Reply With Quote
Old 04-04-2007, 06:14 PM   #3 (permalink)
View toyomoho's Photo Gallery
The industry standard for excess oil burning used to be 1 quart per 1K miles. Have someone do compression or leak down test to determine it the problem is rings, valves, etc. Any oil leaks, white smoke upon cold start up, PCV system OK? Might try a little heavier engine oil.
You loss rate is not that bad, bad is 2 quarts per 1K miles.
Old 04-04-2007, 06:33 PM   #4 (permalink)
View tnmk's Photo Gallery
I was losing a qt every 700. I tore it down and replaced t he rings. Now I burn nothing at all. Rings were very gummy. If that's the reason you're burning you might want to try what someone else suggested after I had mine torn down. I don't know if this works, but someone said to pour 1/2 a bottle of Seafoam in the oil and drive it for 500 miles, then do an oil change. That will supposedly clean up those rings. That's assumiing of course that gummy rings is your problem. If it's valve seals, well then those probably need to be changed out.
Switching to synthetic after a good flush may also help, but again there are no guarantees. First you need to find the source of the problem.
If it blows smoke upon startup after sitting overnight, it's valve seals. If it blows smoke when you rev, it's rings.
Change out your PCV b4 you do anything though.
Good Luck
tnmk is offline   Reply With Quote
Old 04-04-2007, 09:41 PM   #5 (permalink)
View motu 56's Photo Gallery
The saturns have a similar problem and they use this method to fix it. Remove the spark plugs and crank the motor so that you can pour at least 3 or 4 ounces of seafoam or marvel mystery oil in each cylinder. Put the plugs back in and let the car sit for a day.Remove the spark plugs and crank the motor until the fluid is out of the cylinders. The solution will often free up the rings and improve the oil consumption. It is a cheap fix.
motu 56 is offline   Reply With Quote
Old 04-05-2007, 06:50 PM   #6 (permalink)
TokyoRacer's Avatar
View TokyoRacer's Photo Gallery
Take out all the oil, so theres none there to burn.
Kyle's 1990 Corolla SR5 - 2001 Protege ES
TokyoRacer is offline   Reply With Quote
Old 04-06-2007, 05:24 AM   #7 (permalink)
Dave's
Gameroom cash: $124350
View Dave's's Photo Gallery
^ That's what I did in my '92 Camry with 245K miles. Then I quit putting gas in it 'cause it just kept burning it too. So far it still rolls down hills just fine.
Dave's is offline   Reply With Quote
Old 04-06-2007, 06:15 AM   #8 (permalink)
Resident asshole
Flashmn's Avatar
Gameroom cash: $352045
View Flashmn's Photo Gallery
"Free up the rings"... lol, rings dont get stuck to begin with. Only time I've seen rings "stuck" is when the piston dome collapsed due to detonation squeezing the rings in between them. Also rings dont move, they stay at the same position all the time, thats why you place them with the gaps on the opposite ends of the piston circumference.
Major causes for burning oil is valve seals or piston rings. Neither really has a quick fix.
If its the rings, re-hone and re-ring the engine.
If its the valve seals, replace them.
Old 04-06-2007, 09:52 AM   #9 (permalink)
View nsiqui10's Photo Gallery
LMFAO dave, that was hilarious, and i agree with hlashmn there is no real quick "fix" BUT u can slow it down, as said about, but in a heavier oil, and throw some lucas into the mix, bout 1 litre, anyways hope that helps
YEeEAa
nsiqui10 is offline   Reply With Quote
Old 04-09-2007, 12:19 AM   #10 (permalink)
View 94_Rolla_Guy's Photo Gallery
http://www.toyotanation.com/forum/t187223.html
This will include you.....
Ah when she was in her glory, Not so nice anymore 358k 17years old her time is getting short ....
94_Rolla_Guy is offline   Reply With Quote
Old 04-09-2007, 03:28 AM   #11 (permalink)
Resident asshole
Flashmn's Avatar
throw in some lucas? Lucas makes alot of stuff, do you mean gear oil, no you dont want to put that in there.
Old 04-09-2007, 04:27 PM   #12 (permalink)
View 96_9c1's Photo Gallery
Auto RX
96_9c1 is offline   Reply With Quote
Old 04-09-2007, 09:10 PM   #13 (permalink)
retiredat44's Avatar
View retiredat44's Photo Gallery
Exclamation
there is no cheap fix. You cannot add metal and steel to missing and worn away metal. YOu can at best thicken oil. With thicker oil. YOu must replace worn parts with new parts. I guess some people refuse to accept that.
retiredat44 is offline   Reply With Quote
Old 04-09-2007, 11:18 PM   #14 (permalink)
thanks for the input everybody
i know there is no quickfix
i use quaker state high milage 20-50
and i have been changing my oil more often it seems consumption is going down
and i heard lucas is crap i checked out bobistheoilguy.com
im just going to change my oil every 2000 miles
Old 04-10-2007, 12:38 PM   #15 (permalink)
Vroom?
freakinbox's Avatar
View freakinbox's Photo Gallery
doesn't sound all that bad...
I say first of all look at the age of the car. Thats not to bad for something that is 13 years old
1989 Corolla sr5, 4af, 1990 gts seats, TRD short shifter.
http://www.cardomain.com/ride/2061750
freakinbox is offline   Reply With Quote
2.7L oil capacity incorrect gonesurfing 2nd Generation (2005+) 34 02-11-2011 12:09 PM
Men, Women and Oil Changes... BLUEMEANIE Off Topic 15 09-26-2007 09:42 AM
Should i switch Oil type? Mighty~Mart Camry & Solara Lounge 13 04-04-2006 09:01 AM
Snake Oil that really works. Stop Oil leaks pixelpadre Off Topic 2 05-16-2005 08:36 PM
1990 N/A Auto :( dave_id Supra Forum 6 08-26-2004 12:18 PM
