Transmission won't downshift - Toyota Nation Forum : Toyota Car and Truck Forums
Old 04-05-2007, 10:02 AM   #1 (permalink)
on full afterburner
Gameroom cash: $1347897
I have a 97 Corolla with 4-speed auto w/ OD and lately it's been refusing to downshift, even with the gas pedal floored there is a 4 or 5 second delay until it starts accelerating.
It feels very sluggish and I can't get up to speed on the highway quickly enough to merge safely. Any help is appreciated.
Old 04-05-2007, 10:32 AM   #2 (permalink)
BANNED
View w203's Photo Gallery
Change in tranny fluid might be beneficial.
w203 is offline   Reply With Quote
Old 04-05-2007, 12:16 PM   #3 (permalink)
View toyomoho's Photo Gallery
See if the engine/trans setup has a downshift throttle cable going from the throttle pulley to the trans. This tells the trans the throttle is fully open. The cable can get out of adjustment.
Old 04-05-2007, 12:55 PM   #4 (permalink)
on full afterburner
The transmission fluid and filter was just changed a few months ago.
How would I go about adjusting this cable? Where can I find it?
Old 04-05-2007, 02:11 PM   #5 (permalink)
View crypticlineage's Photo Gallery
Just a thought: May be you should also clean the throttle body and plate? Google is your friend.
crypticlineage is offline   Reply With Quote
Old 04-05-2007, 02:35 PM   #6 (permalink)
When driving on a hwy the trans should kick down when you floor the pedal, if not there is a problem. Start looking at the throttle body pulley there may be two cables, one going to the pedal, the other to the trans.
Old 04-08-2007, 08:58 AM   #7 (permalink)
on full afterburner
Checked out the cables, there seems to be no slack in them at all, no need to tighten.
Is there any other possible culprit?
Old 04-08-2007, 09:48 AM   #8 (permalink)
2005ToyotaCorollaS
View daniel2002p's Photo Gallery
check the level of ur tranny fluid again, make sure there is enough in there after the change
D
What do the mlm gurus know that you don't?
Find out how they play by a different set of rules
than everyone else... and... how your company
teachings are actually causing you to fail!
http://www.financialfreedomfordummies.com
daniel2002p is offline   Reply With Quote
Old 04-08-2007, 10:59 AM   #9 (permalink)
on full afterburner
Just checked the level and everythings okay.
What else can it be?
Old 04-15-2007, 12:21 AM   #10 (permalink)
on full afterburner
Ttt
HELP: Serious Transmission Problems arcasmachineracing Camry & Solara Lounge 23 06-22-2008 11:53 PM
Found a $350 camry, but not sure if i can fix it Figit090 1st & 2nd Generation (1983–1986 & 1987-1991) 37 01-02-2007 02:29 PM
99 SR5 2wd Transmission Downshift cedargrove 4Runner Lounge 1 12-29-2005 10:26 PM
Transmission failure. Very sad. alchu Camry & Solara Lounge 1 06-14-2004 10:06 AM
