Corolla 1997 engine temperature - Toyota Nation Forum : Toyota Car and Truck Forums
Old 04-05-2007, 10:07 AM   #1 (permalink)
Rollamaster's Avatar
View Rollamaster's Photo Gallery
Hello all. i am a new owner of a used 1997 Corolla with 115k KMS on it. Its a 1.8 manual DX and seems to be in a good shape. I am not sure what are the normal enginne temperature for corolla engines. The guage quickly (within 10-20 mins) comes to the middle of the scale and stays there with minor variations. Should i drain the radiator only for maintainance reasons or should i not bother. Please advice. THANK YOU IN ADVANCE
Rollamaster is offline   Reply With Quote
Old 04-05-2007, 12:30 PM   #2 (permalink)
View toyomoho's Photo Gallery
Sounds like the system is working OK. Check the condition of the coolant. Does it look clean and red, green or whatever color is supposed to be, not dark or rust colored or thick? When was the coolant last changed? The coolant is usually changed about every two to three years as the additives start to degrade. If you do change it, read up on flushing the system and what coolant to use.
Old 04-05-2007, 01:14 PM   #3 (permalink)
View motu 56's Photo Gallery
The temperture gauge should read at operating in less than 10 minutes, unless it is a very cold day. When in doubt change the coolant, refill it with distilled water and antifreeze to a 50/50 mixture. I would also change the thermostat.
motu 56 is offline   Reply With Quote
Old 04-06-2007, 12:27 AM   #4 (permalink)
View rice's Photo Gallery
normal!
rice is offline   Reply With Quote
Toyota Engine code vivian General Discussion 22 12-27-2008 01:16 AM
How do you warm up your car? kenratboy General Discussion 64 09-05-2007 11:20 PM
HELP is '93 Corolla 1.6 interference engine? 93corolla5speed Archived Corolla threads 15 01-04-2007 07:10 AM
Engine temperature problems HuchoHucho Archived Corolla threads 3 11-27-2005 06:17 AM
