corolla 1989 air /fuel mixture to poor - Toyota Nation Forum : Toyota Car and Truck Forums
Old 04-06-2007, 05:43 PM   #1 (permalink)
View goebezig's Photo Gallery
Corolla 1989 1300cc
2e Engine whit carburetor
air/fuel mixture screw do not react when I turn it in ore out
when motor stationary runs, it go fast and slower always up and down
mixture is to poor,
but air /fuel screw do not react when I turn it
I have clean the carburetor but nothing helps
goebezig is offline   Reply With Quote
Old 04-07-2007, 08:40 AM   #2 (permalink)
Resident asshole
Flashmn's Avatar
Gameroom cash: $352045
View Flashmn's Photo Gallery
How do you know the mixture is poor? Did you plug it into an engine exhaust gas analyzer.
The air/fuel screw only adjusts idle.
2E carburettor is very known for having the vacuum slide sticking, and the only (well the easiest and cheapest) way to fix it is to get a new one or put a 4A-F carb on it.
Old 04-07-2007, 09:16 AM   #3 (permalink)
yes i have a exhaust analyser ,and it not react wenn i turn the screw its de oval screw ,i have made a special tool for turn it
normaly must co arond 2 but now it is 0.15
vacuum slide is working fine ,ihave expect it wen i open the carburator just a new
car have onley 40000km running
it is olmost a showroom model
sorry for my spelling i am from belgium
greeting luc
Old 04-21-2007, 03:16 PM   #4 (permalink)
Donald's Avatar
Gameroom cash: $201420
View Donald's Photo Gallery
I have clean the carburetor but nothing helps [/QUOTE]
When you cleaned the carburetor, did you take all the jets out and blow air through them and all the passages?
If not, you might have blocked jets or passages.
Yamaha makes a carburetor cleaner for motorcycle carburetors, it is very expensive, but if you can get it I would recomend that you fill your carburetor with it and let it soak overnight, then drain it the next day, and blow air through all the jets and passages.
I have had excelent results using this cleaner. It removes all the fuel varnish and deposits, without damaging rubber or plastic parts. It is the next best thing to muriatic acid (which will destroy rubber parts)
'88 Corolla, AE92 SR-5, 7A-FE swap/GT-S suspension
'87 Corolla, AE82 FX-16, 4A-GZE swap (autocrosser)
'03 Tundra 4X4 Access Cab, (FX tow vehicle/Home Depot runner)
Modification: Changing something to what you thought it should have been from the start!
Donald is offline   Reply With Quote
Old 04-21-2007, 03:44 PM   #5 (permalink)
Tanks for info
i have fix the problem
it was a hole between co screw and needle it was dirty and not open
I have clean it whit carb cleaner en a lot of air
Now I can adjust it and it listen to my adjustment now
But now I have more info needed
De screw just under de co screw it was hidden behind a blind stop
whats the best position for this screw , i have turn it and now not more the correct position
I have a link whit screw I mean
http://users.pandora.be/kimkelly
History of the Corolla Ratko Corolla Lounge 26 06-16-2010 04:20 AM
Toyota Japan Launches NEW Corolla Sedan & Fielder JoeyW Toyota News 31 12-07-2008 05:19 PM
2003 Camry Se Intake In Pic!! rgud 5th & 6th Generation (2002-2006 & 2007-2011) 72 04-25-2007 10:03 PM
1989 Toyota Corolla SR5 Missing Bolt/thingy retiredat44 Archived Corolla threads 39 11-21-2006 03:09 PM
1989 corolla 4a-f choke problem voodooblacksmit Archived Corolla threads 0 12-09-2005 09:05 AM
