4af high idle - Toyota Nation Forum : Toyota Car and Truck Forums
Old 04-07-2007, 05:45 PM   #1 (permalink)
View gus310's Photo Gallery
4af high idle
my corolla has a wicked high idle, almost 3k rpms. i sprayed some starter fluid around the vaccuum liines and it only revved a bit when some got into the carb. i have the idle adjust screw all the way out. if i push back on the throttle linkage it will drop down, is there any further adjustment for the idle, can i pull out the main throttle (rod??) and rotate it or anything? if i can track down a stock air filter will it bring the idle down at all? how can i fix this?
gus310 is offline   Reply With Quote
Old 04-10-2007, 05:10 AM   #2 (permalink)
bump
Old 04-11-2007, 03:33 PM   #3 (permalink)
Gameroom cash: $150700
View 90 GP's Photo Gallery
Once warmed up is the choke valve (butterfly) fully open? There is a electric element inside choke housing to dissengage choke when engine is warmed up. Possibly the choke is sticking ( spray cleaner around butterfly valve in carb). If it hangs up your idle will be fast and not drop down to idle speed. Also check all vaccuum lines for leaks.
90 GP is offline   Reply With Quote
OBDII codes Phi Hardcore Tech and Competition 12 12-24-2011 09:38 AM
Excessively Low Idle After Long Period of High Speed ('94, 4cyl) Corsulian 3rd & 4th Generation (1992–1996 & 1997–2001) 6 02-15-2009 05:48 PM
High Idle @ startup hughesar 2nd Generation (2000-2004) 8 10-04-2006 02:27 PM
1993 V6 high idle... AlphaMale 3rd & 4th Generation (1992–1996 & 1997–2001) 6 01-11-2005 07:00 AM
