loose noise coming from gbox :| - Toyota Nation Forum : Toyota Car and Truck Forums
Old 04-09-2007, 12:24 PM   #1 (permalink)
View aarong420's Photo Gallery
I'm having some trouble figuring out whats wrong with my g-box. when the car is on and not in gear, it would sometimes make a noise as though something was bouncing around in there!! A very light noise..
When i give it a small rev,...on acceleration it makes NO NOISE, but when its decelerating the noise comes in.....a little worse than idle. It sounds like if a stone or sumthing is in there, but why wouldnt it make noise when its being accelerated?
if anyone has any idea what this may be please help, i dont wanna ruin my gbox, if its not already
Also what the correct way to topup and check for the rite level of fluid in a 20V gbox?
aarong420 is offline   Reply With Quote
Old 04-09-2007, 09:21 PM   #2 (permalink)
KDM is in
REN69's Avatar
Gameroom cash: $273221
View REN69's Photo Gallery
Sounds more like a loose heat shield to me.. but you never know.
Old 04-10-2007, 10:28 AM   #3 (permalink)
na it aint the heatshield.....that would be a more ratteling noise... this noise sounds like every so often with vibration, sumthing would touch slighty...was thinking maby the release bearing was bad, cuz i didnt change it when i replaced the clutch....but i cant find any to buy here, is there any other release bearing i can use?
Old 04-10-2007, 12:33 PM   #4 (permalink)
Vroom?
freakinbox's Avatar
View freakinbox's Photo Gallery
wheel bearing?
Does it only do it when the car is moving?
1989 Corolla sr5, 4af, 1990 gts seats, TRD short shifter.
http://www.cardomain.com/ride/2061750
freakinbox is offline   Reply With Quote
Old 04-10-2007, 08:07 PM   #5 (permalink)
auh, no man...sounds nothing like a bad wheel bearing...
ok picture this...drop a stone into a blender....hear the noise it makes, a kinda screwd up noise....well its the same noise, just not constant, its a once in a while, "especially when decelerating"
im as confused as everyone elce reading this thread..
BTW, is there a check oil level anywhere for the 20V gearbox?...how would i know if its too full or too little? are there any marks anywhere?
Old 04-11-2007, 08:28 AM   #6 (permalink)
All-Trac Guru
ghost_ryder35's Avatar
View ghost_ryder35's Photo Gallery
remove all of the mounting screws / nuts and remove glove box, inspect and then reinstall properly tightening everything down. Should be good to go,
89 Corolla All-Trac Sedan White 188,xxx (Sold)
89 Corolla All-Trac Wagon Blue 172,xxx (Current)
ghost_ryder35 is offline   Reply With Quote
Old 04-11-2007, 10:59 AM   #7 (permalink)
mind my lack of knowladge...the glovebox will be the part with all the gears inside i take it?.....you sure nuthing will come flying out.? And would i have to take down the whole box for this?
weird noise coming from engine bay bobs Camry & Solara Lounge 1 01-15-2006 01:06 PM
Excessive wind noise 2005 Tacoma psmerdon 2nd Generation (2005+) 12 09-26-2005 03:18 PM
What could this noise be? dna59 General Discussion 13 08-12-2005 08:56 AM
Need help - humming noise coming from engine meng-chieh General Discussion 3 06-10-2005 09:39 PM
ratling noise coming from passenger seat Newbie General Discussion 1 12-13-2002 10:34 AM
