Brake pad replacement - Toyota Nation Forum : Toyota Car and Truck Forums
Old 04-11-2007, 08:36 AM   #1 (permalink)
View FrontRowe's Photo Gallery
New to forum and have a 2004 Toyota Corolla S. Does anyone have instructions on replacing the rotors and front brake pads.
Thanks
FrontRowe is offline   Reply With Quote
Old 04-12-2007, 12:21 AM   #2 (permalink)
BANNED
View w203's Photo Gallery
After car is on jack stands with wheels off, look behind the calipers for two 14mm bolts one up and one down below. Remove them and take off calipers. If bolts are tight which mine were use a breaker bar. It should then be self explanatory, replace metal shims from stock to new brake pads then reinstall everything.
w203 is offline   Reply With Quote
Detailing your vehicle (Exterior) Pb Detailing & Car Care 222 05-15-2011 08:50 PM
Caliper lock up + Brake Pad out of Place = F***ed Rotor atomix099 3rd & 4th Generation (1992–1996 & 1997–2001) 14 02-07-2007 05:58 AM
Rear Brake Valve Replacement spageroni 89-95 Toyota Pickup/Hilux 5 03-02-2006 01:31 PM
Uneven brake pad wear CCCP Camry & Solara Lounge 6 10-29-2005 10:27 PM
