Vehicle shakes! - Toyota Nation Forum : Toyota Car and Truck Forums
Old 04-11-2007, 03:58 PM   #1 (permalink)
View anxious's Photo Gallery
Question Vehicle shakes!
My car, Toyota Corolla LE 2001, shakes while running. It shakes too much in the speed range between 60 and 72 miles per hour. Can anybody give me tips on it?
anxious is offline   Reply With Quote
Old 04-11-2007, 04:21 PM   #2 (permalink)
View stubborn1's Photo Gallery
Have you checked your tires to see if they are balanced? Start with the easy stuff before you get into the suspension.
stubborn1 is offline   Reply With Quote
Old 04-11-2007, 04:32 PM   #3 (permalink)
thx!
Old 04-11-2007, 06:08 PM   #4 (permalink)
I don't hate C3H8
rezzle's Avatar
View rezzle's Photo Gallery
http://toyotanation.com/forum/t114978.html
http://toyotanation.com/forum/t18156.html
Ricers - Imitate, Racers - Originate.
1989 Corolla GTS -4agze propane (rebuilding ... again)
2005 Subaru Legacy (we'll see if if lasts as long as the Yota's)
2008 Yaris
rezzle is offline   Reply With Quote
Old 04-11-2007, 06:09 PM   #5 (permalink)
ok, many thanks, guys! I will check the tires.
Old 04-11-2007, 06:44 PM   #6 (permalink)
retiredat44's Avatar
View retiredat44's Photo Gallery
Question
can you give more info on when it shakes? at idle, in gear, at what speeds,? at what speeds does it not shake? I don't see how anyone can go on such little info..
when was the last work done on it, and if so, what was done?
retiredat44 is offline   Reply With Quote
Old 04-12-2007, 11:50 AM   #7 (permalink)
My started shaking immediately after I had the two front tires replaced with brand new ones. Probably the alignment was adjusted too. It does not shake too much at idle, low speed. And it is running quite smoothly over 72 mph. It shakes too much between 60~72 mph.
Old 04-12-2007, 12:04 PM   #8 (permalink)
Feel the vibe.
vibebreaker's Avatar
View vibebreaker's Photo Gallery
maybe you need wheel balancing or alignment.
vibebreaker is offline   Reply With Quote
Old 04-12-2007, 01:52 PM   #9 (permalink)
Exclamation
I have heard lots of stories about some tires that have given some car owners fits with shaking like you describe. I realize that tire shops wil not help you unless they see a nail in the tire or a defect while the car is sitting on a car lift rack. They will need to drive the car to feel it. So, you will have to convince them to drive it at those speeds. Otherwise you wil end up buying a new set to replace that set. I hope the tire shop does not screw you.
good luck..
Old 04-12-2007, 02:00 PM   #10 (permalink)
Crowbar911's Avatar
View Crowbar911's Photo Gallery
Is it possible that the tire place did not put on the counterweight for the wheel?
Crowbar911 is offline   Reply With Quote
Newbie here: Getting 95 camry today! Mjakaz95LE Introduce Yourself Here 24 04-21-2009 06:06 AM
2006 Chart: Recall woes grip Toyota fargoal Toyota News 30 07-25-2006 11:14 AM
FS: 1994 Corolla DX - 1 Owner - North New Jersey Anuj Vehicles 2 12-22-2005 09:52 PM
could you get away with it bondobondo General Discussion 46 07-06-2002 12:00 PM
