50K what is that I have to do? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 04-12-2007, 08:32 PM   #1 (permalink)
View motopasta's Photo Gallery
I am getting close to 50K miles and wanted to ask you if there is anything that I need to do for proper maintainance. So far I have just replaced oil every 3000 miles and checked the level of the fluids BUT I never really replaced anything like: coolant, brake shoes and pads, spark plugs, air conditioniniong gas (freon?)....
when are all these things due for replacement?
overall I have no problem to report
thank you
motopasta is offline   Reply With Quote
Old 04-12-2007, 09:51 PM   #2 (permalink)
View toyomoho's Photo Gallery
What year of car? Your owners manual or the website below should provide details on scheduled maintenance.
http://smg.toyotapartsandservice.com/
Front brakes should have squealers that make a noise when the pad gets low; rears usually last a lot longer. If OEM plugs should be good for 100K, Freon does not wear out. Might think about a coolant change if original. If an automatic trans think about changing the fluid more often then scheduled as this is a cheap and effective way to prolong its life.
Old 04-12-2007, 10:28 PM   #3 (permalink)
View chocowallet's Photo Gallery
Coolant and Trans flush every 30k and at 60k i think a new timing belt.
chocowallet is offline   Reply With Quote
Old 04-13-2007, 12:02 PM   #4 (permalink)
Timing belt
It is my understanding that the timing belt is actually not a belt but a chain! with a tensioner I guess? so does it need replacement periodically? i thought cam chains don`t need to be replaced...am I wrong?
Old 04-13-2007, 08:25 PM   #5 (permalink)
KDM is in
REN69's Avatar
Gameroom cash: $273221
View REN69's Photo Gallery
Well.. considering that you didn't even post what year Corolla you have you're bound to get a lot of responses that don't even apply to your car.
BTW, at 50k miles I would say you're due for a rear diff check up.
02 - 50k service recommendations? dr.02 1st Generation (1995.5–2004) 2 04-08-2007 07:37 PM
Buying a 2002 Tundra with 50K xxxthisdoodxxx 1st Generation (2000–2006) 5 11-01-2006 07:14 PM
My gen 3 pics (50K warning)... Peacemaker 3rd & 4th Generation (1992–1996 & 1997–2001) 15 03-28-2006 12:28 AM
50k Miles Since Last TuneUp- Noticing Missfire 5spd V6 ClrTail Camry & Solara Lounge 4 08-14-2005 02:37 AM
