Head Swap 88 to 92? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 04-14-2007, 01:46 AM   #1 (permalink)
92 Corolla 4AFE
View 91boz's Photo Gallery
Head Swap 88 to 92?
I have a 92 4afe that has a blown head gasket. I need to know if the cylinder heads from a carbureted 88 or 89 will fit? I have access to both and I would like to send one out to a machine shop for a rebuild while I use the 92. Is there going to be a problem with the the fuel injection on the carbureted head? What other problems would I have to watch out for?
91boz is offline   Reply With Quote
Old 04-14-2007, 09:10 PM   #2 (permalink)
92 Corolla 4AFE
Bump! Anyone?
Old 04-14-2007, 11:02 PM   #3 (permalink)
4Aaron GE's Avatar
View 4Aaron GE's Photo Gallery
Check to see where your injectors are located. If they're mounted on the head, then it's definitely a no-go. If they're on the manifold, you might be able to do it, but it'd depend on the ports. No way to get the head/mani off of a 93+?
What? No animation? Bah.
4Aaron GE is offline   Reply With Quote
Old 04-15-2007, 07:34 PM   #4 (permalink)
92 Corolla 4AFE
Thanks 4AaronGe! The injector ports are located on the cylinder head and the carburated version does not have these 4 ports. I guess I have to pull the bad head and have it rebuilt.
Old 04-16-2007, 08:41 AM   #5 (permalink)
Resident asshole
Flashmn's Avatar
Gameroom cash: $352045
View Flashmn's Photo Gallery
a AE92 head wont fit the AE100 series.. well it will, but whats the point when you'd have to change other things aswell to the point you can get a new head with the sum.
5efe head gasket still leaking, I need advice fast !!! reezytercel Tercel, Paseo, Starlet, and Sera Forum 9 05-23-2010 11:26 PM
4AFE head swap 1992corolla Archived Corolla threads 16 07-08-2005 12:50 AM
head swap tercel_speed Tercel, Paseo, Starlet, and Sera Forum 3 03-30-2005 05:29 PM
92 tercel motor swap kasper92tercel Tercel, Paseo, Starlet, and Sera Forum 3 12-12-2004 02:36 AM
4a-c SOHC to DOHC head swap? O 16581 72452 5 Hardcore Tech and Competition 0 03-06-2004 11:43 AM
