AE92 Suspension Setting? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 04-14-2007, 03:58 PM   #1 (permalink)
TOTAL NOOB
forpinks's Avatar
View forpinks's Photo Gallery
LOL! I just read an article once, that an AE92 with a slightly modified suspension handles better than a BMW 3-series? is this true?
How can I make my old AE92 sedan perform better or atleast match the road grabbing capability of the 3-Series?(but not performance) 'any tips or suggestion on that?
And how many members here have a full coil-over system, upgraded bars, and 15-16" light-weight rims and sticky tires? how is the road vibration/noise?
BTW: I found out that my AE92 swerves to the right a bit when I floor the gas with its stock 13" rims and Michelin threads, is camber allignment a possible problem or is it the tires that have only been aligned 8 months ago? If I change my suspension setup will this be eliminated/greatly reduced?
THANKS PIPZ!
-2003 Corolla S A/T.
forpinks is offline   Reply With Quote
Old 04-15-2007, 11:05 AM   #2 (permalink)
Gameroom cash: $134355
if it pulls to the right when you gas it... that isn't alignment but torque steer... nothing you can do unless you get a later silvertop axle.....
my ae92 handles damn well... it's an sr5 with stock rear sway, GTZ front sway, GTS front strut, suspension techniques springs, kyb struts, and tein upper mounts (front camber adjustable).... it will outhandle most mr2's out there.....
91-93 suspension tamalpro MR2 Forum 1 01-21-2006 09:30 PM
