Alarm problems - Toyota Nation Forum : Toyota Car and Truck Forums
Old 04-15-2007, 05:04 PM   #1 (permalink)
n00b
ecuaman801's Avatar
View ecuaman801's Photo Gallery
Alarm problems
I have a problem with my wife's 96 Corolla's factory car alarm. Ever since she bought it, it's been like this. When you open any car door, you need to start the car or at least turn the key to on within 30 seconds or the alarm goes off. The alarm then won't stop until you start the ignition. Is there a way to turn off, cut a wire, pull a fuse, or anything, to stop the alarm? I don't want to do anything to screw up the car - I just want this stupid thing to stop.
ecuaman801 is offline   Reply With Quote
Old 04-15-2007, 08:27 PM   #2 (permalink)
2005ToyotaCorollaS
View daniel2002p's Photo Gallery
if it is a factory alarm then unlocking the car with the key in the dr cylinder will disable the alarm
D
What do the mlm gurus know that you don't?
Find out how they play by a different set of rules
than everyone else... and... how your company
teachings are actually causing you to fail!
http://www.financialfreedomfordummies.com
daniel2002p is offline   Reply With Quote
Old 04-15-2007, 08:49 PM   #3 (permalink)
n00b
ecuaman801's Avatar
It's not disabling though. I just want to take the fuse out or cut the wire so it doesn't go off again. We don't have the alarm remote to it. It must be broken. Can I disable it without taking out another electrical system?
Old 04-15-2007, 10:51 PM   #4 (permalink)
2005ToyotaCorollaS
u sure its a factory alarm?
D
Old 04-16-2007, 09:21 AM   #5 (permalink)
n00b
ecuaman801's Avatar
As far as I know. It uses the car's horn, not a separate one. If I could just rip it out then I would. Maybe I'll check under the hood today and see...
Old 04-16-2007, 05:41 PM   #6 (permalink)
2005ToyotaCorollaS
some aftermarket use the fact horn.... look up under there and see if the sec box says toyota on it... or some other brand
D
Old 04-21-2007, 01:44 PM   #7 (permalink)
n00b
ecuaman801's Avatar
Well, I looked underneath and can't see anything resembling the alarm anywhere. I'll look some more maybe.
But is there anyone who knows how to just clip a wire to disable the alarm? I don't want to disable the horn (I tried - pulled the fuse on alarm and it disabled the whole horn). i just want to disable or rip out the alarm. Please just answer me that... Thanks!
Old 04-21-2007, 08:42 PM   #8 (permalink)
2005ToyotaCorollaS
if its a factory alarm then there should be a fuse called "security" or "VIP"
D
Old 04-22-2007, 11:06 AM   #9 (permalink)
TIEyota fighter ace
Piloter's Avatar
Gameroom cash: $143400
View Piloter's Photo Gallery
The factory alarm should be a module under one of the front seats.
WIP AE102.
Piloter is offline   Reply With Quote
Old 04-22-2007, 06:10 PM   #10 (permalink)
n00b
ecuaman801's Avatar
It worked! I went and unplugged the alarm underneath the drivers seat and no more alarm! Do you know how happy my wife is now? She's had this problem ever since she bought it a few years ago. Now we'll be able to open the door and not worry about sticking the key in the ignition! Yeah!!!!
Old 04-22-2007, 06:12 PM   #11 (permalink)
TIEyota fighter ace
Piloter's Avatar
Glad all that time I had my seats out could be of use to somebody. =)
WIP AE102.
Old 05-02-2007, 06:59 PM   #12 (permalink)
n00b
ecuaman801's Avatar
I forgot to mention it, but that fix didn't work (unplugging the VIP alarm box). It doesn't start unless this box is plugged in. Is there a way to just clip the wires or re-program the computer? I'm really trying to avoid paying the Toyota dealer $45 to look at it and tell me there's nothing we can do... PLEASE HELP!
Old 05-02-2007, 07:21 PM   #13 (permalink)
TIEyota fighter ace
Piloter's Avatar
There's probably fixes in place to prevent you from just tying together signal wires, and Toyota's not likely to publicize service specs (and how to bypass) for a security system. The dealer may be your only bet, unfortunately.
WIP AE102.
Old 05-03-2007, 03:19 AM   #14 (permalink)
BANNED
View w203's Photo Gallery
Seems like the alarm brain unit went bad. That or you have a faulty wiring somewhere.
w203 is offline   Reply With Quote
Old 05-03-2007, 08:57 AM   #15 (permalink)
2005ToyotaCorollaS
well when u unplug it u also disable the starter... now with the VIP system all that means the starter wire was cut in half and the VIP alarm was regulating it, so do this, take off your cars underdah, and find the ignition harness, and there u will see a piggyback harness to the stock ign plug, running to the alarm... just remove that piggy back harness and bam ur good to go
D
1993 MR2 Factory Alarm rcustomrods MR2 Forum 10 04-07-2009 01:14 PM
Alarm help needed urgently fsphoto 5th & 6th Generation (2002-2006 & 2007-2011) 24 06-26-2007 03:11 PM
Problem: Alarm – Immobilizer – TVIP – Intrusion jhaag 1st Generation (2003-2008) 8 12-09-2006 04:41 PM
Alarm system is alarming! lowcost Archived Corolla threads 5 07-24-2005 11:05 AM
04 Corolla S - Factory Alarm bradp50 Audio, Video, and Security - Tech 6 08-15-2004 10:09 PM
