92 Corolla DLX Wagon won't start - Toyota Nation Forum : Toyota Car and Truck Forums
Old 04-15-2007, 07:50 PM   #1 (permalink)
View RGBell's Photo Gallery
USA 92 Corolla DLX Wagon won't start
My son-in-law tried to jump-start his 92 Corolla DLX wagon (lights left on) and managed to cross wire it. It blew the 100 amp fusable link. All other fuses are OK. The engine fires when the ignition switch is in the START position but does not fire when in the ON position. Is this a cooked ECU or is there another possibility that I have overlooked?
RGBell is offline   Reply With Quote
Old 04-16-2007, 10:47 AM   #2 (permalink)
All-Trac Guru
ghost_ryder35's Avatar
View ghost_ryder35's Photo Gallery
double check the fuses in the engine bay, and under the dash. so it runs when in the start position, but not the on position? or does it just crank? I wouldnt jump to a bad ecu, if it was it shouldnt do anything, specially not fire (assuming fire means the engine is getting spark and fuel and running until it is put into the normal run position on the ignition).
89 Corolla All-Trac Sedan White 188,xxx (Sold)
89 Corolla All-Trac Wagon Blue 172,xxx (Current)
ghost_ryder35 is offline   Reply With Quote
Old 04-16-2007, 08:08 PM   #3 (permalink)
It RUNS in the start position. I checked all of the fuses that I could see. Any idea which fuse controls the ignition when it is in the ON position?
Old 04-19-2007, 02:32 PM   #4 (permalink)
drz 4age corolla
drz4agecorolla's Avatar
View drz4agecorolla's Photo Gallery
did u c if the timing belt went bad because the same thing happend to me n after i changed the fuse the car still wouldnt turn on.....n my mechanic told me it was my timing belt.....that tends to go bad on corollas
drz4agecorolla is offline   Reply With Quote
Old 04-19-2007, 07:23 PM   #5 (permalink)
This turned out to be the fuse for the fuel injection. I checked that fuse twice and it was OK. Makes no sense to me. The car was taken to Toyota service and they claimed that the fuse was bad. Hopefully my son-in-law learned a valuable lesson. It cost him around $250 to have it towed and have diagnosed by Toyota. Thanks for the suggestions.
History of the Corolla Ratko Corolla Lounge 26 06-16-2010 04:20 AM
92 Corolla Turn's over, won't start yigo65 Archived Corolla threads 9 04-04-2007 03:32 PM
94 to 92 wagon parts tranferability 92wagon 3rd & 4th Generation (1992–1996 & 1997–2001) 2 10-18-2005 06:55 PM
1991 Corolla Wagon - Newbie Question CrazyBred Archived Corolla threads 1 07-22-2002 09:13 PM
