It is possbile for you o replace it, and it is not hard at all.
Go to your toyota dealership and get the box, should be around 40 bucks
Then to instal, you remove the bezzle around the box and climate control sutff, then unscrew a few screws, and then take out th broken box and the cup holder. they are enclosed in a metal fram, then you unscrew th box from th frame, and then revrse evrything that you did to get it out.
You will need a phillips had screw driver for the screws and a flat head to get the bezzle off.
