Help: Fixed "click" but now wont idle - Toyota Nation Forum : Toyota Car and Truck Forums
Old 04-17-2007, 01:36 PM   #1 (permalink)
View ricsilverbullet's Photo Gallery
background: 2000 chevy prizm/toyota corolla. last 2 weeks intermittent starting, "click" problem as referred to on this forum.
i was taking the fan out to give me some room so i could take the starter out when i noticed that the 2 long skinny bolts were loose on the starter. i decided to take it out so i could clean up the contacts with a wire brush for now. well i got the bottom bolt of the starter out , but couldn't find the top bolt it was driving me insane, so i took the intake off and lifted it and noticed the top bolt to the starter was on the drivers side, so i took it off , cleaned it cleaned the contact points and put it back in , put the upper back on.
go to turn car on it starts up fine prob even quicker than before but now it wont hold idle, at first it jumps to like 2500rpm slowly comes down and then the rpm start to drop enough to hear the engine sputter till it finally dies.
i'm guessing vaccum leak, should i put a new gasket on the upper intake??
ricsilverbullet is offline   Reply With Quote
Old 04-17-2007, 02:52 PM   #2 (permalink)
View toyomoho's Photo Gallery
Could be the intake gasket but first check for loose or cracked vacuum hoses. You can attempt to find the leak by using a propane torch (gas on but no flame) and running it around the areas the leak might be. The engine will pickup idle when it takes in the propane. You can also use starter fluid but be careful using it.
Also check the wiring to the IAC valve and MAP/MAF sensor (if you have them).
Fluctuating idle with AC on and brake pressed - DEFINITIVE FIX!!!! ovrrdrive 89-95 Toyota Pickup/Hilux 12 03-24-2007 04:24 PM
Proper Idle speed for 22re capinoy 89-95 Toyota Pickup/Hilux 2 01-29-2007 07:16 AM
Random idle stalling fixed Lyons451 Camry & Solara Lounge 1 05-08-2005 08:34 AM
Low Idle when cold and when AC is on Tom Simon Hardcore Tech and Competition 3 04-02-2005 03:04 AM
No Idle after motor rebuild wrenchdad MR2 Forum 0 01-09-2005 08:19 AM
