After changing the clutch, i totally destroyed the engine mounts. So the result was that, while driving, the car would shake after reaching 40mph. So I switched the front, rear and driver's side engine mounts, and I still feel a slight shaking when ever I open the throttle. I know for sure that there's still something else wrong because when I put the car on stands, put it in gear and open the throttle, the engine sways.
I have a feeling that the passenger's side mount is done, too. Also, whenver I hit approx. 3k rpm, I hear this oscillating noise coming from the wheels/transmission/axles that sounds kinda like a wow wow wow wow wowowowow.
I'm totally confused, by the oscillating sounds because the tires seem ok. I guess it could be the alignment.
Any thoughts?
TIA,
Gino
