4a-ge Breaking Down "please Help" - Toyota Nation Forum : Toyota Car and Truck Forums
Old 04-22-2007, 04:24 AM   #1 (permalink)
View blondieguy's Photo Gallery
HI ALL, I HAVE A "90" 4A-GE COROLLA THAT HAS BEEN PLAYING UP. WHEN FIRST STARTED IT SEEMS OK. USUALLY PLAYS UP AFTER ABOUT 5 MINS. STARTS MISFIRING. I HAVE REPLACED SPARK PLUGS, FUEL FILTER. YES THERE IS A VERY LITTLE OIL IN THE VALLEY. LITTLE MORE OIL IN DISTRIBUTOR (HAVE CLEANED THIS AND NO DIFFERENT). FUEL PRESSURE IS ABOUT 35 PSI AND ABOUT 50 PSI UNDER LOAD (EVEN WHILE PLAYING UP).
COULD IT BE A FAULTY COIL ?
TPS SETTING ?
ANY HELP WOULD BE GREATLY APPRECIATED.
THANKYOU.
blondieguy is offline   Reply With Quote
Old 04-23-2007, 11:44 AM   #2 (permalink)
All-Trac Guru
ghost_ryder35's Avatar
View ghost_ryder35's Photo Gallery
TPS SETTING ?
THANKYOU.
have you done a compression test? loosing any coolant?
89 Corolla All-Trac Sedan White 188,xxx (Sold)
89 Corolla All-Trac Wagon Blue 172,xxx (Current)
ghost_ryder35 is offline   Reply With Quote
Old 04-23-2007, 06:28 PM   #3 (permalink)
Not Losing Any Coolant , Have Not Done A Comp Check. Going To Put Leads On Today If I Can Get Them Local.
Thanks For You Reply.
Old 04-23-2007, 07:25 PM   #4 (permalink)
KDM is in
REN69's Avatar
Gameroom cash: $273221
View REN69's Photo Gallery
I would assume it's the spark plug wires, look at them closely to see if there any cuts on them, they could be grounding to metal.. it happened to me before with another car.
Old 04-23-2007, 07:47 PM   #5 (permalink)
The TN Member
View punter's Photo Gallery
Sounds like leads or possibly dizzy.
Try the leads first, if thats no good then try a cap and rotor.
Check engine light coming on??
Say no to huge pics as signatures.
punter is offline   Reply With Quote
Old 04-24-2007, 03:45 AM   #6 (permalink)
THANKS ALL FOR YOU REPLIES ""I FOUND IT"" AFTER SPENDING MOST OF THE DAY. NOT BEING ABLE TO SPEND MONEY. I EVENTUALLY ONCE NEARLY DARK OUTSIDE I SAW A SPARK JUMPING FROM THE DISTRIBUTOR CAP (CRACK).
THANKS AGAIN.
