Bad Head Gasket - Toyota Nation Forum : Toyota Car and Truck Forums
Old 04-22-2007, 11:52 PM   #1 (permalink)
92 Corolla 4AFE
View 91boz's Photo Gallery
Bad Head Gasket
My 92 4AFE was leaking oil for some time around the oil pressure sender switch. I thought the problem was a leaky sender switch but it was leaking from above the switch right where the head meets the block. I pulled the cylinder head today and a bad head gasket was the cause of the leak. I am going to take it in tomorrow for a valve grind and resurfacing.
How do I post pictures on this forum?I would like to show pictures of the head gasket as it shows how bad a condition it was in.
91boz is offline   Reply With Quote
Old 04-23-2007, 12:27 AM   #2 (permalink)
BANNED
View w203's Photo Gallery
Your gonna need an image host, I suggest photobucket.com since I'm familar with it. After uploading the pics they should give you a link. Copy that link and on the post box where you see a yellow pic with the sun and a mountain click on it and paste the link.
w203 is offline   Reply With Quote
Old 04-23-2007, 12:49 AM   #3 (permalink)
92 Corolla 4AFE
Thanks I'll try that and will hopefully have the pix up soon.
Old 04-23-2007, 01:06 AM   #4 (permalink)
92 Corolla 4AFE
Bad head gasket pictures. Look at the 2nd picture. This is the lower left corner of image #1. You can see why I was losing oil above the alternator.
http://i156.photobucket.com/albums/t...z/P1020297.jpg
http://i156.photobucket.com/albums/t...z/P1020299.jpg
Old 04-23-2007, 11:37 AM   #5 (permalink)
All-Trac Guru
ghost_ryder35's Avatar
View ghost_ryder35's Photo Gallery
Sorry, the pics are easier to see when you do it like this. Damn headgaskets
89 Corolla All-Trac Sedan White 188,xxx (Sold)
89 Corolla All-Trac Wagon Blue 172,xxx (Current)
ghost_ryder35 is offline   Reply With Quote
Old 04-23-2007, 12:31 PM   #6 (permalink)
92 Corolla 4AFE
How is that done??
Old 04-23-2007, 12:34 PM   #7 (permalink)
92 Corolla 4AFE
I see! finally figured it out. Thanks!
Old 04-26-2007, 12:08 PM   #8 (permalink)
92 Corolla 4AFE
I got my cylinder head back from the rebuilder yesterday and car is up and running. What a difference in performance. I did have two exhaust valves on the #3 cyl.replaced as both were distorted "Tulliped". One hitch that I have is that the radiator fan goes on as soon as the igniton key is turned on. I will check around the thermostat for a loose wire or bad sensor. Anyway here are some pics. of the head.
Old 04-27-2007, 01:24 AM   #9 (permalink)
92 Corolla 4AFE
The fan problem was caused from the a/c high pressure switch. The switch was not connected and caused both fans to turn on with the ignition switch.
Corolla/Prism Head Gasket wheredoesthisgo Archived Corolla threads 3 03-24-2007 10:39 AM
Doing the Head Gasket - 22RE BSDeality 89-95 Toyota Pickup/Hilux 15 02-23-2007 03:36 AM
NEED Help blown head gasket 93 corolla 1.8 and bad rear motor mount darcsyde Archived Corolla threads 3 12-12-2006 10:06 PM
head gasket ? Blazin674 Archived Corolla threads 0 04-08-2006 08:55 PM
New Toyota Head Gasket, no more leaks!!! reezytercel Tercel, Paseo, Starlet, and Sera Forum 1 03-06-2006 09:05 PM
