AE82 noises while turning - Toyota Nation Forum : Toyota Car and Truck Forums
Old 04-25-2007, 05:17 PM   #1 (permalink)
Chitty Chitty Vroom Vroom
View Criard's Photo Gallery
Exclamation AE82 noises while turning
I have been noticing a popping noise while turning. It happens moreso only when I turn left, and depends on how sharp I'm turning and what speed I'm going. for example if I come to a stop and make a slow 90* turn left into a parking lot, the popping noises will be fewer but more pronounced. higher speeds and rounder turns will produce a more rapid, but slightly smoother sounding popping.
I have had a semi-mechanic friend suggest it might be the tie rods?
btw, hi I'm new!
Criard is offline   Reply With Quote
Old 04-26-2007, 09:47 AM   #2 (permalink)
Ghostridin the whip
Ukrainian102's Avatar
View Ukrainian102's Photo Gallery
Most likely it's the CV joints.
http://www.cardomain.com/id/ukrainian102
1995 Corolla DX, 2000 Camry LE, 2004 Highlander V6 AWD
Ukrainian102 is offline   Reply With Quote
Old 04-26-2007, 10:12 AM   #3 (permalink)
All-Trac Guru
ghost_ryder35's Avatar
View ghost_ryder35's Photo Gallery
and fairly easy to replace too
89 Corolla All-Trac Sedan White 188,xxx (Sold)
89 Corolla All-Trac Wagon Blue 172,xxx (Current)
ghost_ryder35 is offline   Reply With Quote
Old 04-26-2007, 10:51 AM   #4 (permalink)
LIFER
CDUFF777's Avatar
View CDUFF777's Photo Gallery
replace worn cv's soon - they can break and have your car careening out of control. My buddy wrecked on the highway due to this problem - luckily he lived.
1 JDM FROM HERE IN JAPAN
CDUFF777 is offline   Reply With Quote
Old 04-26-2007, 02:50 PM   #5 (permalink)
cv joint. alright, can a get a fewmore details? what is it? how much does one cost? should I just take it to a mechanic and let them deal with it?
Old 04-26-2007, 03:43 PM   #6 (permalink)
Resident asshole
Flashmn's Avatar
Gameroom cash: $350545
View Flashmn's Photo Gallery
How does a CV joint break enough to cause your car to get out of control?
Only thing it does is attach the driveshaft to the hub, it wouldnt wear out to the point it would cause an accident, because you wouldnt be able to drive the car with a broken one.
Old 04-27-2007, 04:22 AM   #7 (permalink)
LIFER
CDUFF777's Avatar
don't ask me the damn thing snapped while he was speeding down the highway in japan.
Old 04-27-2007, 10:35 PM   #8 (permalink)
drz 4age corolla
drz4agecorolla's Avatar
View drz4agecorolla's Photo Gallery
it can b the cv joint or either the left lower ball joint....i had the same problem n it was the left lower ball joint
drz4agecorolla is offline   Reply With Quote
Old 04-27-2007, 11:57 PM   #9 (permalink)
thanks for the help guys!
AE92 & AE82 Brake upgrade options.... freakinbox Older Generations (1969-1987) 8 09-13-2007 04:41 AM
t100 noises when turning Mando236 T-100 2 11-22-2006 07:38 AM
Hyde's turning radius has been made a 1/3 tighter ... JekylandHyde MR2 Forum 7 06-26-2006 05:32 PM
Brake noises onomatos Archived Corolla threads 0 11-30-2005 05:28 PM
probably getting an ae82 toyotaspeed90 Archived Corolla threads 3 02-20-2005 07:07 PM
