Which Head? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 04-25-2007, 09:26 PM   #1 (permalink)
View poorboychevelle's Photo Gallery
Which Head?
Flat out, which 4A heads flow the best. Im looking to probably build a turbo'd motor, and I'd like to know which heads will let me cram the most air in there the easiest. 20V? Red top, blue top, big port, small port?
poorboychevelle is offline   Reply With Quote
Old 04-25-2007, 09:33 PM   #2 (permalink)
KDM is in
REN69's Avatar
Gameroom cash: $251221
View REN69's Photo Gallery
Do you even know what everything means? Blue tops only came in big ports while red tops came in both big and small port, 20Vs came in silver and black top.. confused yet?
I would say first the 4AGZE (which you didn't mention) next would be the redtop bigport.
Both 20Vs have been successfuly turbo'd before, the Silver top seems to be the choice out of the two.
Old 04-26-2007, 07:54 PM   #3 (permalink)
The TN Member
View punter's Photo Gallery
Blacktop 20v, proven to be the best head for forced induction.
You will need heavier valve springs if you're pushing more than about 25psi down it.
Say no to huge pics as signatures.
punter is offline   Reply With Quote
Old 04-26-2007, 10:45 PM   #4 (permalink)
View Gsolo's Photo Gallery
I may be wrong but i believe the silvertop head is better flow because the valves aren't shrouded. IIRC the blacktop head valves are slightly shrouded in the attempt to boost comp. can't find any pics of the combustion chambers...so i'm probably wrong
And heres a pic of head flow between small port 16v and silver 20v.....pic is from billzilla.org hope no one thinks i'm stealing it
1990 Geo Prizm with Silvertop 20V swap
Toyota Tech
Gsolo is offline   Reply With Quote
Having head problems w/ a 22RE sidingmonkey 89-95 Toyota Pickup/Hilux 22 04-05-2007 04:28 PM
Corolla/Prism Head Gasket wheredoesthisgo Archived Corolla threads 3 03-24-2007 11:39 AM
PART 1: 3S heads revised allblackalltrac Hardcore Tech and Competition 4 01-15-2007 05:49 AM
Coolant Consumption After Head Gasket Replacement. Bullz_EyE Pre-88 Toyota Pickup/Hilux 4 05-06-2006 09:23 AM
